Author Topic: Heat shunts/clips for soldering, and soldering sensitive components  (Read 4800 times)
Offline IdahoManTopic starter
I don't like having heat or margnetic fields around electriclal devices, but you have to solder things. So, what are the best methods for protecting components (or anything) from the heat of soldering when you have to solder them? (or heatgun, flame, whatever even)
What about the use of heat/thermal-shunts (clips, alligator clips, needle-nose)*? What are the rules there, and has anyone ever done an experiment/video (using probes or FLIR) on where the heat actually goes, over a length(s) of time at certain applied temperatuers?
*Example:
"A small piece of beeswax may be placed between the protected unit and the heat shunt.
When the beeswax begins to melt, the temperature limit has been reached. The heat
source should be removed immediately, but the shunt should be left in place."
Offline oldway
Re: Heat shunts/clips for soldering, and soldering sensitive components
« Reply #1 on: April 23, 2018, 05:58:56 pm »
You can't safely solder or desolder a germanium transistor without it.
But it does not need to be a copper jaw, a long nose or a universal pliers do the job very well.
Offline jmelson
« Reply #2 on: April 23, 2018, 06:07:38 pm »
Yes, as Oldway says, for germanium, you need it.  But, look at modern SMT components.  The whole board is heated to 250 C for several minutes, and 100% of components are expected to survive for the full life of the equipment after that!
I haven't used a heat sink clip when soldering since about 1965.
Jon
« Reply #3 on: April 23, 2018, 06:09:43 pm »
Something with copper or aluminium jaws would be ideal, but in practice steel usually does the trick. My favourite tool for this is the humble surgical hæmostat, aka forceps, available very cheaply on fleaBay or you favourite alternative online vendor.
Offline Gregg
« Reply #4 on: April 23, 2018, 11:36:17 pm »
Here are some steel ready made tiny spring clips that work well.  They can be ground to finer points.
https://www.amazon.com/gp/product/B06XCFPLVZ
