For example the common honeywell zone-valve for a furnace, runs off 24VAC, and has a coil resistane of 20ohms or so.
When these motors hit the end of their travel, and the motor can't push any harder, and it stops, does it just sit there, with the 24V AC still applied, or is there any internal circuitry that bypasses the motor when it stop's, or, is it just built to take it?
If there's no locking mechanism, and the value is active-open, then I guess the power has to be kept applied, to keep it open? Otherwise it would close, is that it?
