Well I seriously thinking to build ( Yes build - make ) my own tool .
The
Mini-Din strain relief clip its wide as 3.5mm , so the tool for it it must be as 4.0mm wide .
The Classic
Din strain relief clip its wide as 5.5mm , so the tool for it it must be as 6.0mm wide.
So the "Mini-Din & Din" tool must be as 6mm wide,
with two holes (two sizes) with the
diameter of :
5.0 - 5.5 mm for Din
4.0 - 4.5mm for the Mini Din
(By having in mind that in both cases, the max diameter of cable will be used)
@shafri Thanks , you are a
Pal (edited)
