If you are starting in electronics, you will not stop at one multimeter.
Very soon, you will feel the need for a second one. So dont think that you are buying the device of your life.
But you can consider it as your first meter, and it will last you a long time, even if afterwards you buy a second one, you will still use this one, as it as also the advantage to be small.
In this usage scenario, I would also expect this to be a valid reasioning. Heck, as I started to get going in electronics for hobby use about 3 years ago to build my home bench, i started with one used handheld DMM from ebay- now I have 5 DMMs here (working condition...) and well, the stuff seems tp reciprocate...
For a first DMM, to get the feet wet, I also would say that TrueRMS is nice, but no dealbreaker. In most cases when repairing things it is important to know THAT voltage is there, but not exactly how the waveform runs.
So some budget version of decent quality is usually sufficient, and with my knowledge of today I also considered buying a 50€$ DMM as a secondary handheld in addition to the stuff and bench DMMs I already have.
My looks went to the Uni-T 139C, which would cover most of my use cases except hard work at mains voltage distributions- here I have different equipment available.
Otherwise, even when repairing household appliances, usually you do NOT measure current directly with the multimeter, only check voltages. And then the often mentioned flimsy 250V glass fuse as protection for the Amps input becomes quite irrelevant.
Yes, you have to know what you are doing (and more important: what not to do and how to have some standard procedures while working), but apart from that these devices are quite capable for doing electronic work.
Usage in the industrty for electrical work is a very different field with other requirements.
So, as the Amprobe 510 was mentioned, it also would IMHO fit the bill as a first DMM, simply to begin with. And with experience (and hopefully some saved money due to the repairs being done) a second meter or more specialized stuff like a clampmeter or probes will follow soon.
Questin for the OP: From which shops are you being able to order that charge decent shipping costs?
