Author Topic: Help for design simplest circuit for 6*1wat white LED in parallel(LED Driver)  (Read 8738 times)
Offline rozehTopic starter
Hi everybody
I'm doing a project to design a circuit. I have to connect 6 number of 1wat white in parallel. this circuit will work on a ship with 24v supply. Do you have any idea for making it very simple? I already saw this:
Super simple high power LED driver
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
Offline GK
Here is the LED display power supply I designed for my discrete digital clock project. My displays have almost 200 10mm LED's in total each with a nominal V drop of 2V. I run a 100R series dropper on each from the regulated 3V. Overall it is relatively efficient.
I think it's pretty simple and straight forward.
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Thanks dear GK
I think it's a bit complex for me. ;D
What is your opinion about this circuit?:
Offline mariush
a waste of money and chips?
What do you guys have against led drivers ?
1w led ... 2.8-3.4v voltage  1w .. that's about  300mA  ... times 6 is about 19-20v ... so 19v 300mA ... no problem driving a led driver from 24 volts.  Get a buck led driver and you're done. Or get two and put just 3 leds on each led driver... they're cheap at about 1$ each
Put the leds in series and get one of these :
http://uk.farnell.com/zmdi/zled7000-zi1r/led-driver-buck-0-75a-sot89-5/dp/1898426RL
http://uk.farnell.com/diodes-inc/ap8801sg-13/ic-led-driver-buck-0-5a-8sop/dp/1825358
Offline GK
Thanks dear GK
I can't see that working with those 20k resistors in series to the regulator inputs, even in the simulator. You probably should be looking for a dedicated LED driver IC as already mentioned. A switching one too otherwise with a 24 supply you will be dissipating a lot of power in the regulator(s), and especially so if you insist on connecting the LEDs in parallel instead of series.
Offline mikeselectricstuff
    • Mike's Electric Stuff
If you have 24V available you really want to wire them in series, not parallel
Day Job: Mostly LEDs
Offline IanB
But the assignment says they have to be connected in parallel. You have to follow the rules of the assignment. You have to do what you are told. Authority must be obeyed!  >:D
@mariush
Thanks. It's a good idea. also if I can find these ICes in my country. :D
@GK and @mikeselectricstuff
but the series has a big problem. if one of them will burn then other LEDs will not work. :(
@IanB
 :D
Offline poorchava
  • Troll Cave Electronics!
In parallel if one burns, the others get more current and another one burns, and then they all share the current and they are all toast. Unless you driver LEDs way below nominal current so that you have enough headroom in case of failure.
@poorchava
Really?
Offline IanB
If the LEDs must be run independently, then you first need a circuit to drive a single LED from a 24 V supply, then you duplicate this circuit six times.
The circuit to drive a single LED from a 24 V supply will be a suitable current regulating buck driver IC for LEDs.
If a 24 V supply is too high to efficiently drive a single LED you might consider first generating a lower voltage rail, say 6 V with a DC/DC step down converter, and then running the LEDs from this.
Offline IanB
@poorchava
Really?
This will happen if you literally connect the LEDs in parallel and then try to drive them all from a single current source. But you shouldn't do that.
Which is the cheapest way, guys? and which is the best for a ship? series or parallel?
Offline IanB
Well what are you trying to design?
Is it for area lighting, spot lighting or beacons? Interior or exterior? Are the lights to be controlled as a group or individually switchable? Is the design a one-off, or for volume production?
It's hard for anyone to say what is "best" without knowledge of what is needed.
for beacins.
exterior.
individually switchable.
Volume production.
Offline IanB
for beacins.
exterior.
Volume production.
Just for clarity, do the six LEDs make one beacon switched on and off as a group, or do the LEDs make six separate beacons that can turn on and off independently?
It would be common to put LEDs in series when there are a group of them. But they could also be arranged in two groups of three, or three groups of two.
The normal approach would be to use a purpose designed LED driver IC. Pick one that matches the supply voltage, output voltage and LED current requirement. LED lights are so common now that many driver chips exist.
Offline hlavac
  • Country: cz
I would make a switching buck converter to create a supply rail with voltage about 1V above the forward drop of the LEDs from the 24V input for power efficiency, then give each LED its own current limiting resistor and power all the resistor - LED pairs in parallel from that rail. That ensures reliability when individual LED fail open or change drop voltage drastically.
Good enough is the enemy of the best.
Offline Corporate666
  • Remember, you are unique, just like everybody else
I would use something like the RT8472 from Ricktek.  It is a buck switching LED Driver which can take from 5V to 30V directly and will run up to 1A output current.  It also costs $0.25/ea and has a dimming/switching input for easy control of the LED current output.
I would run the 6 LED's in series in one string.  Failure of one LED is not so much a problem - LED's are diodes and they should not be designed for failure anymore than you would design any other part for failure like any other diode or capacitor or resistor.  I always see people wanting to design around possible LED failure - IMO there is no reason for that other than either a bad design originally that is going to fail, or being burdened by the past when bulbs used to burn out (a bad way to do modern designs). After all, we don't design solid state transistors to be replaceable in modern electronics, even though we did with vacuum tubes... same thing.
I would heat sink everything REALLY well, then pot the whole thing with clear epoxy and forget about individual component replaceability in favor of reliability/waterproofing.
It's not always the most popular person who gets the job done.
Unfortunately I couldn't find those ICs(you mentioned) in my country. What is your opinion about this circuit?
3wat LED constant current
I want to put 3*1wat LED in parallel for each of this circuit. thus, for 6LED I can use of two this circuit for each.
like this
Offline ttp
like this
This is just 3.33V voltage supply, no current limiting. In my opinion no good for LEDs.
Offline senso
  • Country: pt
    • My AVR tutorials
Using just a comparator, a couple passives and some transistors you can make a poor mans buck led driver:
http://www.instructables.com/id/Poormans-Buck/
Thanks ttp and senso
I don't need to dimming the LEDs. I just want to drive those in parallel. ::)
Offline senso
  • Country: pt
    • My AVR tutorials
Remove the dimming and you get a constant current led driver....
