Author Topic: Help identify component item 1  (Read 767 times)
Offline denimdragonTopic starter
  • "Hole charge chaser and wanna-be o-scope fixer"
« on: March 31, 2021, 04:51:09 pm »
Here is the first component. I'm still tackling the warehouse task,
so I have been find all sorts of cool looking components. Any ideas?  :-//
"Hi there. I'm short in the hair department, do you mind if I pull a few strands from your head? Thanks!"
Offline YurkshireLad
Re: Help identify component item 1
« Reply #1 on: March 31, 2021, 04:53:18 pm »
It looks like an old torture device!  ;D
« Reply #2 on: March 31, 2021, 06:39:42 pm »
 :-DD I could see that. I wonder if it's some type of early test system for a section of a PCB with pads matching the thick pin array above the ICs?
Offline alsetalokin4017
« Reply #3 on: April 01, 2021, 12:00:58 am »
turbo encabulator transverse interface buffer
Offline james_s
« Reply #4 on: April 01, 2021, 12:55:58 am »
I've seen DIP sockets that had a weird pinout like that, seems like I ran into that in an older Heathkit device.
Not sure what that is though, maybe some kind of prototype?
Offline WattsThat
« Reply #5 on: April 01, 2021, 04:54:26 am »
They look like late sixties NASA style flat pack NOR gate IC’s with hi-rel pins. Maybe early RTL.
Yes, Heathkit had some weird ideas in the early seventies. They had Molex make special staggered pin 0.1” IC strip sockets because the engineers in Benton Harbor were afraid Joe Six Pack couldn’t solder in-line pin sockets without bridging pins.
The original product was stamped and formed tin plated flat strip in roll form. You cut or snapped off strips of 7 or 8 pins, times two, and inserted into the pc board and then soldered. Once in place, you snapped off the top the held the pins together. They were absolute junk and they abandoned the idea as kit chip counts went higher and the sockets starting being the reason properly built kits didn’t work. As TTL became mainstream and cheap sockets hit the market, they went with custom one piece sockets with the same stupid offset pins.
Offline Jwillis
« Reply #6 on: April 01, 2021, 07:21:18 am »
Flux capacitor
Offline gcewing
« Reply #7 on: April 01, 2021, 11:49:30 am »
I don't think it was just for hobbyists. I've seen some old TV circuitry using DIP sockets with staggered pins like that. I'm guessing it's because the PCB manufacturing process they had at the time couldn't cope with pads that close together.
