Author Topic: Help identifying component  (Read 1125 times)
Offline Analog KidTopic starter
« on: October 06, 2026, 07:08:14 am »
Capacitors?
Too fat for a ceramic cap? I have a sneaking suspicion they're actually MOVs or some such. Anyone know for sure what they might be?
Online NE666
Re: Help identifying component
« Reply #1 on: October 06, 2026, 07:26:37 am »
Speculation but I'm inclined to agree that they aren't ceramic caps as I've never seen those carry certification laboratory marks.
I think the presence of those markings suggests that, whatever they are, they are considered protection / protection related devices. Possibly MOVs, as you suggest.
Online PA0PBZ
Online SparkyFX
« Reply #3 on: October 06, 2026, 10:29:04 am »
DIN VDE 560-2 has the title "Specifications for capacitors; Coupling capacitors for voltages up to 1000V and power up to 0.5kvar"
Support your local planet.
Offline SamElectronics616
« Reply #4 on: October 06, 2026, 11:41:19 am »
I found independent component references identifying KC102K as a capacitor, including examples where it is specified as 1 nF, 250/400 V.
The physical size isn't necessarily evidence against it being ceramic. These are likely high-voltage ceramic disc capacitors, where the relatively large body is useful for achieving the required voltage rating.
For the yellow component, the marking appears to be something along the lines of 560-2 / 565-1L2. That one is harder to identify conclusively from the photograph alone. The shape and construction are consistent with a ceramic disc capacitor, but I'd want the exact marking and, ideally, a capacitance measurement to identify its value and voltage rating confidently.
Why they aren't likely to be MOVs?
An MOV normally has a voltage designation/part number associated with its varistor voltage, and its construction/markings are different. More importantly, KC102K is documented as a high-voltage capacitor designation, not a varistor.
« Reply #5 on: October 07, 2026, 04:49:29 am »
I definitely need a capacitance meter.
Maybe my next project.
Offline bolek_bolek
