The component marking on the pcb reads MIS1 i already tested it with the multimeter and i get nothing on resistance, diode test, or continuity and the component is good as the board was pulled from a working fax machine, i have another one just like that where that component literaly broke in half due to an electrical discharge from thunder storm, i don't have the board here with me but i think that component is connected to the same tracks of the capacitors, also i have some 56k modems lying around and all have a similar component near the phone line connector but the pcb markings read RV1 and the ring colors on the components are different. Will try to get some more pictures. Thx for the help
