Author Topic: Help to identify an odd shaped MAC CLASSIC resistor  (Read 678 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: June 10, 2020, 12:26:51 am »
Sorry for the silly question but I got this 20ohms resistor (RP2 in the schematics) in line on my primary circuit.
I am struggling to identify it. It does not appear a regular resistor. It is a thermistor?
« Last Edit: June 10, 2020, 12:35:02 am by gkmaia »
Offline TimFox
Re: Help to identify an odd shaped MAC CLASSIC resistor
« Reply #1 on: June 10, 2020, 02:53:35 am »
Yes, an NTC thermistor.  Note that the schematic indicates a “cold” value for RP2 resistance.
« Reply #2 on: June 10, 2020, 02:59:04 am »
thanks for your answer.
so if it is negative it as current flows through it will increase temperature and reduce resistance. I imagine to a point where it will just be a jumper.
if that is correct i could replace it with a jumper temporarily for now just for testing purposes.
Also what is the reason for such device right out of the mains?
Offline bob91343
« Reply #3 on: June 10, 2020, 03:49:50 am »
I believe it's to reduce the inrush current.  When it gets hot, its resistance is low for normal operation.
« Reply #4 on: June 10, 2020, 04:18:03 am »
So it starts smoothly. As i mentioned it is the  fine to replace it with a jumper or maibe a fuse?
Offline floobydust
« Reply #5 on: June 10, 2020, 05:16:23 am »
No, the part burns due to a short/overload on the SMPS primary side. If you must jumper the NTC, add a lightbulb in series and it should not stay lit. It's rare these parts burn up due to their old age.
First I would check the main switching transistor for shorts, bridge rectifier etc. Need to see more of the schematic/model number.
« Last Edit: June 10, 2020, 05:20:21 am by floobydust »
Offline james_s
« Reply #6 on: June 10, 2020, 05:59:53 am »
For temporary testing it should work to use a jumper, but if the NTC failed you'll want to make sure there isn't a short that fried it. It's there to reduce the inrush when switched on, that increases the life of the power switch and reduces the stress on the rectifier and bulk filter capacitor.
« Reply #7 on: June 10, 2020, 09:22:45 am »
nice, thanks!!!! Will give it a go.
