Do you understand how to formulate and solve simultaneous equations?
Assign names to all the components (e.g. R1, R2 etc), and denote the current through Rn as In. Similarly denote the voltage at each node.
Then use KCL on each node, and KVL on each loop, e.g. I1=I2+I3, V3=V1+V5, and add Ohms' law e.g. I1=(V5-V3)/R1.
Solve the resulting equations. Once you have done that a few times, you will develop an understanding for the patterns, and then be in a position to take "short cuts".
I note the OP is good at starting threads, but poor at following up to indicate whether or not they have understood: 10 threads, 3 followups. Doesn't look good.
