Author Topic: Help with attiny4 coding  (Read 3461 times)
Offline minipowerTopic starter
« on: November 14, 2020, 01:14:29 am »
I have no idea what I'm doing. But reading and cramming the info, this what I have come up with.
Getting your feedback and recommendations would help me a lot.
I'm trying to blink 2 led's in sequence over and over.
To save as much 3v coin cell power. I am trying to put the attiny4 into the slowest CPU clock, since I'm only blinking led's - turn everything off except the internal low-power 128khz clock.
Set pins 1(PB0) and 3(PB1) to outputs.
To help save power. Set pins 4(PB2) and 6(PB3) to inputs with pull-up resistors.
blink Red led 4 times then short pause. Then Green led 5 times then long pause
Start the blinking loop over and over.
I have been studying these webpages.
https://arduinoelectronics.wordpress.com/2014/01/06/ultra-low-power-led-flasher-with-attiny/
https://sites.google.com/site/dannychouinard/Home/atmel-avr-stuff/low-power
https://www.garlicsoftware.com/articles/files/0662584a661f5b1cdb84dc2c17935537-1.php
I have attached a block diagram of what I'm trying to accomplish.
This is the code I have so far. As you can see. I'm not sure if I have correctly put the cpu in slowest mode and turned on the internal low-power 128khz clock.
 * 2 leds.c
 * Created: 11/10/2020 11:27:18 AM
 * Author : rascal
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/delay.h>
#define RED PB0
#define GREEN PB1
int main(void)
cli();                   // Disable global interrupts before initialization
CCP-0xD8;              // Unlock protected register
CLKPSR=256;            // Clock division factor 256 (1000)
CKSEL=11
CLKPR=(1<<CLKPCE); CLKPR=256;   // Low-power 128Khz clock / 256 = ?Khz
or?
CLKPR=(1<<CLKPCE); CLKPR=4;   // 128Khz / 16 = 8Khz
or?
CLKPR=(1<<CLKPCE); CLKPR=8;   // Clock/256
CLKPS=(1<<4);      // Clock division factor 256 (1000)
PRR|=(1<<PRTIM0);        // Turn timer0 off
PRR|=(1<<PRTIM1);        // Turn timer1 off
DDRB=b0011;              // Pins 4 & 6 inputs - Pins 1 & 3 outputs
PUEB=|=(1<<PB2)|(1<<PB3) // Enable Pullup Resistor Pins 4 & 6
ACSR|=(1<<ACD);               // Turn off Analog comparator
//DDRB|=(1<<RED)|(1<<GREEN);  // Set pins 1 & 3 output
/* or ?
DDRB|= (1 << RED);      // Set pin 1 output
DDRB|= (1 << GREEN);    // Set pin 3 output
setup_watchdog(9);          // WDT prescale select 0-9
// 0=16ms, 1=32ms, 2=64ms, 3=125ms, 4=250ms, 5=500ms
// 6=1 sec, 7=2 sec, 8=4 sec, 9=8sec
sei();                  //initialize global interrupts before beginning loop
    /* Replace with your application code */
    while (1)
// Blink PB0 (RED led) 4 times then sleep
  PORTB |=(1<<RED);   // 1 turn the LED on (HIGH is the voltage level
  delay(200);               // wait for 200ms
  PORTB &=~(1<<RED);    // turn the LED off by making the voltage LOW
  delay(100);               // wait for 100ms
  sleep_enable();
  sleep_cpu();          //sleep
  // Blink PB0 (GREEN led) 5 times then sleep
  PORTB |=(1<<GREEN);   // 1 turn the LED on (HIGH is the voltage level
  PORTB &=~(1<<GREEN);    // turn the LED off by making the voltage LOW
  PORTB |=(1<<GREEN);   // 2 turn the LED on (HIGH is the voltage level
  PORTB |=(1<<GREEN);   // 3 turn the LED on (HIGH is the voltage level
  PORTB |=(1<<GREEN);   // 4 turn the LED on (HIGH is the voltage level
  PORTB |=(1<<GREEN);   // 5 turn the LED on (HIGH is the voltage level
  sleep_enable();        // 2 sleep modes to extend the (pause) not blinking time
  sleep_cpu();
  sleep_cpu();
  ISR (WDT_vect) {
  WDTCR |= _BV(WDIE);
Offline rstofer
Re: Help with attiny4 coding
« Reply #1 on: November 14, 2020, 01:53:33 am »
I don't think this will compile:
« Reply #2 on: November 14, 2020, 02:12:38 am »
I think I see what your talking aboot.
Wrong
Correct
CCP=0xD8;              // Unlock protected register
Offline james_s
« Reply #3 on: November 14, 2020, 03:04:15 am »
Is there a reason that you're bothering with a watchdog timer on something that blinks a couple of LEDs? That's normally used to reset the processor if the code crashes so if it's doing something somewhat critical it doesn't get stuck in a bad state. With such a simple program it's hardly worth the bother.
What I would suggest is first get the LEDs blinking with the code as minimal as possible, since you want to put the CPU to sleep between blinks you will probably want your main loop to be empty and just have the whole routine in the interrupt handler. Depending on the duty cycle of the LEDs and how bright you want them to be, you may find that the vast majority of the power is drawn by the LEDs themselves leaving little saved by using sleep. The sleep function is useful when you want to do something like wake up once every 15-60 seconds or so, do something for a few milliseconds like read a sensor and act on the result, then go back to sleep. Once you have an interrupt routine blinking to your liking you can try tweaks like turning off all the unused stuff and putting the core to sleep to save power. One step at a time.
Also I haven't messed with the attiny4 specifically, but I've never done anything to change the CPU clock in the code itself, the clock speed and division factor on parts that support it are controlled by setting fusebits when you program the part. I think some do let you dynamically adjust it from the program but that shouldn't be necessary here, you can run it at 125kHz the whole time.
« Last Edit: November 14, 2020, 03:08:54 am by james_s »
« Reply #4 on: November 14, 2020, 08:02:52 pm »
The attiny4 datasheet says the sleep mode (power down) Can only wake up with INT0 and Pin change and the only timer running is the watchdog time.
So I pretty much stood on the shoulders of others and copied what they did.
I'm using the watchdog to wake up from sleep mode (power down) and to space out the short pause between the 2 blinking led's and the long pause before it starts over.
As you said about the led power draw. I agree in think the led's will be the biggest power drain. I'm planing to experiment with led resistors, so I can dial in there brightness.
After I get some experience with MCU's. I'm going to try to learn how to use the PWM to drive the led's.
I did see using milliseconds to time the blink and pause. I'm not that good to pull it off yet. But would I still need a timer and a way to wake-up the cpu ?
I think I found the correct way to set the cpu speed:
   CLKPSR=(1<<CLKPS3)|(0<<CLKPS2)|(0<<CLKPS1)|(0<<CLKPS0);
I believe this was the wrong way:
   CKSEL=11
I think these are the attiny configuration/fusebits
Disable external reset
Watch dog timer always on
Output external clock
Disable Reset Pin    -   Makes pin 6 into a output. But then you will have to use a High Voltage programmer to program the chip.
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: November 14, 2020, 09:30:47 pm »
« Reply #6 on: November 14, 2020, 10:18:40 pm »
Oh. That shows me that I was closer to correct the 1st time " If closer to correct is a real thing "
Am I understanding it right ?
      CCP = 0xD8;     // Unlock protected register
      CLKPSR = 8;    // Clock division factor 256
Plus I will need to put this before everything. So the compiler knows the cpu clock speed ¿
#define F_CPU=31250
Also I think the delay is wrong.
incorrect.
 delay()
Change to.
_delay_ms()
« Last Edit: November 14, 2020, 11:27:23 pm by minipower »
Offline sleemanj
« Reply #7 on: November 15, 2020, 05:06:55 am »
Long time since I wrote that so I had to have a look at the datasheet again
Yes to change CLKPSR or CLKMS you need to set CCP (configuration change protection) first and then the CLKPSR/MS can be changed for the next 4 clock cycles. See pages 22 (CCP),  34 (CLKMS) and 36 (CLKPSR).
It looks like my code leaves the clock at the main 8MHz system clock and uses the prescaler to get the desired 128kHz, equally you could set the prescaler to no division (CLKPS=0) and set the system clock to use the WDT clock with CLKMS=1 the WDT clock will be less accurate but probably lower power.  You can of course also go slower.
You probably want to read about the Power Reduction Register from page 39 and about MInimizing Power Consumption from page 40
« Reply #8 on: November 16, 2020, 06:35:11 pm »
I'm confused about a few things.
I always thought the cpu speed and timer were 2 different things. One first would select the cpu speed and then choose a timer.
The other is. I don't know how to do the math, of figuring out what the settings I choose equals the cpu speed, or how to reverse the math to work out the settings for the chosen cpu speed.
The cpu speed and prescaler. It's not clicking. How does the prescaler work and what is it's function ?
What setting makes the cpu faster or slower. I'm thinking a 0 makes the cpu faster and 256 makes it slower.
After I did the changes pointed out and placing the missing ; I was able to build / compile it in Atmel studio 7. Except I do not have the correct watchdog timer "invoke"?. So I'm going to look at getting that right.
I have this --  implicit declaration of function 'setup_watchdog' [-Wimplicit-function-declaration]
and then 2 errors at the end  --
static declaration of '__vector_8' follows non-static declaration
'WDTCR' undeclared (first use in this function)
  ISR (WDT_vect) {
     WDTCR |= _BV(WDIE);
« Last Edit: November 16, 2020, 06:42:33 pm by minipower »
Offline james_s
« Reply #9 on: November 16, 2020, 06:46:56 pm »
The clock that drives the CPU also drives the timer, and there is a selectable prescaler on it. For example if you set the CPU clock to 1MHz and select the prescaler to 128 then the timer will be clocked at 1MHz/128, about 8kHz. You can then set the timer to whatever value and it will increment or decrement at that rate. The timer is really just a counter that counts up or down at whatever clock rate you give it, and the starting value can be set to whatever you want and then it will trigger something when it reaches the end of its range.
« Reply #10 on: November 16, 2020, 07:02:05 pm »
So the system clock is 1 thing and the prescaler chooses how accurate the timer is.
So whatever system clock is chosen, you can tell the program to only count either all of the system clock ticks or every 256 system clock tick.
The cpu is running the system clock speed but the timer will run slower ?
The normal/regular system clock. Lowest speed is 1MHZ and using a prescaler just affects the timer. So the cpu is running at 1MHz.
I have the choice to pick what the cpu uses as the system clock.
1. normal system clock
2. the slower low power watchdog timer
3. external timer
Choosing the 128kHz timer makes the cpu run at 128kHz and then if wanted, can make the timer less accurate by using the prescaler ?
« Last Edit: November 16, 2020, 07:17:45 pm by minipower »
Offline sleemanj
« Reply #11 on: November 16, 2020, 08:13:43 pm »
See page 29 of the datasheet
You can drive the system clock from the external, internal or the watchdog oscillator, the prescaler divides the selected clock down before using it.
Offline james_s
« Reply #12 on: November 16, 2020, 08:17:05 pm »
No, it's not accuracy, it's all about intervals and resolution. The longer interval you want to time, the slower you have to clock the timer. If you are dealing with a 16 bit timer then that means it is able to count up to 65,535 ticks before it reaches the end, like a stopwatch reaches an eventual limit of say 99 minutes, 99 seconds, 99 hundredths and stops because it is out of digits. If you clock the timer at 1MHz then the maximum period you can count for is about 15 seconds before the timer will overflow. If you want to measure a longer interval you have to clock the timer at a slower rate so you use the prescaler. Using that same example if you were to set a prescaler to /4 then the timer would be clocked at 250kHz  and you could then measure an interval up to 60 seconds. The CPU clock controls how quickly the CPU executes instructions, the timer is an independent device that just happens to be driven by the same clock source, there is no reason you couldn't build a timer that has its own separate clock oscillator, there is just not really any good reason to do so.
Offline sleemanj
« Reply #13 on: November 16, 2020, 08:18:44 pm »
You can make is slower using the prescaler.  Prescaler = divider.
If you choose 128kHz WDT osc as the input clock source, then apply a prescaler, you clock the system at between 128kHz (Prescaler = 0000) to 500Hz (Prescaler = 1000, 128kHz/256), see page 36 of the datasheet (and also pay attention to the paragraph on page 37)
« Last Edit: November 16, 2020, 08:20:47 pm by sleemanj »
« Reply #14 on: November 16, 2020, 09:14:58 pm »
Ok. I think I'm getting it. My word accuracy = resolution.
And the cpu - system clock is seperate from timer. And the cpu speed is governed by the system clock and if wanted, the prescaler . So
1st is the system clock or which ever clock source chosen.
2nd if wanted the prescaler - which divides the system clock which slows down the cpu speed
3rd dividing the system clock by the prescaler = the cpu speed.
I'm invisioning it like this.
You have a gear 8 inchs in diam and you want to slow it down. You place a larger gear to be driven by the 1st smaller one.
I'm guessing that its ok to really slow down the cpu to blink leds. But if I wanted to read - say - a temperature sensor, Not good. The slower the cpu the less precise the reading.
pulling numbers out my butt.
128KHz cpu speed = a temperature reading once a minute but speed up the cpu and I could get a reading once a second or even more per second.
I will look over those sections and others. But now with the info you guyz have helped me figure out.
« Last Edit: November 16, 2020, 09:31:22 pm by minipower »
Offline james_s
« Reply #15 on: November 17, 2020, 03:18:01 am »
I'm not familiar with the attiny4 in particular but in many of these AVRs there are multiple prescalers, one for each timer, and one for the ADC. The internal block diagram of the chip is in the datasheet but in summary there is one master oscillator that can supply everything and then some of the fancier parts have a second low frequency 32kHz oscillator specifically for timekeeping. The CPU core is driven by the oscillator and in some cases has a rudimentary prescaler, usually with only two settings such as off or divide by 8. This controls the speed that the core executes code and the purpose of the slower speed is to reduce power power consumption.
Peripherals that need a clock such as the timers and ADC each have their own prescaler, this is fed by either the same clock signal feeding the CPU core or by an external timer interrupt clock source. The prescalers for these peripherals are there to add flexibility for reasons already explained. A prescaler is just a divider, it lets you vary the speed that something operates without changing the speed of the oscillator itself which may be clocking multiple different things.
You will need to sit down and study the datasheet to fully understand this stuff, it is all laid out pretty clearly in there.
« Reply #16 on: November 18, 2020, 10:56:08 pm »
thank you guys. Your info is helping. I am having a little difficulty keeping track of all the chips functions and how they affect each other. That should just take time and working experience.
I read that the slower the MCU runs, the slower the programming speed needs to be, about a quarter the speed of the MCU speed. Since the MCU uses software to set the operating perimeters, like speed and pins. If I run the MCU at 500hz would I need to also reduce the programming speed to about 100hz ?
Or can the MCU be reset to default speed and catch the MCU before my settings take place, that will allow a faster programming speed ? Or would it be a good idea to put a 1 second delay at the top of my int main(void) ?
Another unknown is the pin 6 reset pin. If I tell it to be a output, would that stop me from reprogramming it ? Or would that only be affected by the enabling the RSTDISBL fuse bit ? Meaning only high voltage programmer an do anything with the chip.
If I'm able to set the pin 6 reset pin to output and still program it. I will be able to cut out a few lines of code, that set pins 4 & 6 to inputs and enabling the pull up resistors on them. And just use DDRB |= 0xFF to set all pins as outputs.
Reading the datasheet. These are the security setting that either allows reading and writing without having to erase the chip. So as long as I don't accidentally copy and past
NVLB1 = 0
NVLB2 = 0
I will still be able to read and write to the MCU.
Sorry about not putting the sections of the relevant datasheet. I have yet to figure out how to copy and paste them from the datasheet pdf to the forum.
Offline sleemanj
« Reply #17 on: November 19, 2020, 02:26:35 am »
To use the RESET pin as IO then reset must be disabled (fuse), if you disable reset then you can only program if you apply 12v to the reset pin during programming.
I'm not 100% on the TPI speed, but I expect that TPI is done with respect to the default system clock, which is, 1MHz from memory (8 divide by 8).  I couldn't quickly find any reference to the maximum recommended speed for TPI, 1/4 sysclock is true for SPI and I would guess that TPI the same.
Similarly I can't readily see if reset on tinyAVR will reset the system clock registers (CLKPSR and CLKMS) or if they survive reset - I would guess that they get reset, but I wouldn't be certain.
Offline james_s
« Reply #18 on: November 19, 2020, 03:56:49 am »
I know with the attiny13 if you clock it really slow you have to dial down the programming speed. The programming interface is a glaring flaw in the otherwise excellent AVR microcontrollers, it's possible to brick the chip by selecting a clock mode that requires an external clock or crystal in a design that doesn't have one, or by disabling reset. It's a more than 20 year old design so I can't complain too much though, at the time it was somewhat revolutionary in that such simple and inexpensive hardware could be used to program it and the use of flash was really slick back then too. Most prior microcontrollers used EPROM and you either needed an expensive one with a quartz window for erasing or they were OTP.
« Reply #19 on: November 20, 2020, 11:09:34 pm »
I'm stuck again  :-//
When I 1st started playing with all this. I was using the Arduino IDE and a Digispark Attiny85 board.
I worked out the timing to my satisfaction and was going to Port the code to the Attiny4. This is what I ended upo with in the Arduino IDE
#define adc_disable() (ADCSRA &= ~(1<<ADEN)) // disable ADC (before power-off)
//#define adc_enable()  (ADCSRA |=  (1<<ADEN)) // re-enable ADC
void setup()
  // Power Saving setup
  for (byte i = 0; i < 6; i++) {
    pinMode(i, INPUT);      // Set all ports as INPUT to save energy
    digitalWrite (i, LOW);  //
  adc_disable();          // Disable Analog-to-Digital Converter
  wdt_reset();            // Watchdog reset
  wdt_enable(WDTO_4S);    // Watchdog enable Options: 15MS, 30MS, 60MS, 120MS, 250MS, 500MS, 1S, 2S, 4S, 8S
  WDTCR|= _BV(WDIE);     // Interrupts watchdog enable
  sei();                  // enable interrupts
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Sleep Mode: max
void loop()
  pinMode(1, OUTPUT);
  digitalWrite(1, HIGH);   // 1 turn the LED on (HIGH is the voltage level
  digitalWrite(1, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(1, HIGH);   // 2 turn the LED on (HIGH is the voltage level
  digitalWrite(1, HIGH);   // 3 turn the LED on (HIGH is the voltage level
//  adc_disable();          // Disable Analog-to-Digital Converter
  sleep_enable();
  sleep_cpu();
  digitalWrite(1, HIGH);   // 4 turn the LED on (HIGH is the voltage level
  digitalWrite(1, HIGH);   // 5 turn the LED on (HIGH is the voltage level
  sleep_enable();
  sleep_cpu();
  sleep_enable();
  sleep_cpu();
ISR (WDT_vect) {
  WDTCR |= _BV(WDIE);
Page 53 shows this.
9 0x008 WDT Watchdog Time-out Interrupt
Instead of this.
ISR (WDT_vect) {
So I should put this ?
ISR (WDT) {
This is the jumbled mess I have so far.
 * 2 leds.c
 * Author : rascal
#define F_CPU 500UL
#include <avr/io.h>
#include <util/delay.h>
#define RED PB0
#define GREEN PB1
int main(void)
CLKMSR=0x01;                             // Change clock source to Low-power 128 kHz oscillator
CLKPSR=0b1000;                           // Clock division factor 256 (1000) = 500Hz
PRR |= (1<<PRTIM0);                      // Turn timer0 off
DDRB = 0b00000011;                       // Pins 4 & 6 inputs - Pins 1 & 3 outputs
PUEB = (1<<PUEB2)|(1<<PUEB3);            // Enable Pullup Resistor Pins 4 & 6
ACSR = (1<<ACD);                         // Turn off Analog comparator
set_sleep_mode(SLEEP_MODE_PWR_DOWN);     // sleep mode is set here
MCUSR = 0;                               // Clear MCU Status Register
WDTON = (0<<WDE)|(1<<WDIE) ;            //set watchdog in interrupt mode
WDP = 0b1001;          // WDT prescale
// 0000=16ms, 0001=32ms, 0010=64ms, 0011=125ms, 0100=250ms, 0101=500ms
// 0110=1 sec, 0111=2 sec, 1000=4 sec, 1001=8sec
//wdt_enable(WDP=1001);    // Watchdog enable Options: 15MS, 30MS, 60MS, 120MS, 250MS, 500MS, 1S, 2S, 4S, 8S
SMCR = (1<<SE);  //enable power-down sleep mode
    while (1)
  _delay_ms(200);               // wait for 200ms
  _delay_ms(100);               // wait for 100ms
  sleep_enable();
  sleep_cpu();
  sleep_cpu();
  // Watchdog Interrupt Service / is executed when watchdog timed out
  ISR(WDT_vect) {
//  f_wdt=1;  // set global flag
WDTCR |= (1<<WDIE);
These are the build errors I'm getting in Atmelstudio 7
   recipe for target 'main.o' failed
   'MCUSR' undeclared (first use in this function)
        'WDTON' undeclared (first use in this function)
        'WDP' undeclared (first use in this function)
I'm stuck at setting the Watchdog timer Prescaler.
Because of the build errors I'm getting. I'm guessing this is an Arduino thing and not used in AtmelStudio gcc.
Samething here. Or is this a Attiny85 setting and is different on the Attiny4 ?
ISR (WDT_vect) {
  WDTCR |= _BV(WDIE);
It seems 1 of my issues in understanding what to type for the setting I'm trying to use.
Like this. On page 50, the datasheet says
Bits 5,2:0 – WDPn: Watchdog Timer Prescaler [n=3:0]
The WDP[3:0] bits determine the Watchdog Timer prescaling when the Watchdog Timer is running. The
different prescaling values and their corresponding time-out periods are shown in the table below.
If your able to see the changes I have been trying in the Atmel studio code. I'm not understang what I need to plug, that will chose my wanted settings.
Or is there a #include I can use, that allow me to use the Arduino IDE in the AtmelStudio ?
I apologize for the messy code. I have been trying to keep myself to 1 change at a time, so I can keep track of what is really working and what is not.
« Last Edit: November 20, 2020, 11:18:15 pm by minipower »
Offline sleemanj
« Reply #20 on: November 21, 2020, 12:06:31 am »
In regards your Arduino sketch,
  * Tiny 4 does not have ADC, so ADCSRA does not exist and the adc functions are invalid
  * Tiny 4 has WDTCSR instead of WDTCR
Removing the adc stuff and changing the register name to WDTCSR allows your Arduino sketch to compile for ATTiny4 using my 2020.10.10 version of DIY ATtiny Arduino Core selected for Tiny 4.  It's too big (Sketch uses 570 bytes (111%) of program storage space. Maximum is 512 bytes.), but it compiles.  If you lose the "power saving setup" loop then you can compile with room to spare.  Since they are all being set INPUT LOW anyway that should be the default so no need for it.
https://github.com/sleemanj/optiboot/blob/master/dists/README.md#attiny4-attiny5-attiny9-attiny10
Generally speaking ATtiny4 and Attiny85 are two very different chips and have different registers, for an example in your code it does not have an MCUSR which is where the T85 indicates the reset source, the T4 has a RSTFLR register bit 3 of which is WDRF and indicates if the reset was because of WDT, page 52.
WDT_vect is the correct vector name, which you can see in iotn4.h of your installation....
$ cat iotn4.h | grep WDT
#define WDTCSR _SFR_IO8(0x31)
#define WDT_vect_num  8
#define WDT_vect      _VECTOR(8)  /* Watchdog Time-out */
If you have written for the T85 I would suggest you are better to either stick with the x5 series or go to Tiny13 which is mostly the same just with 1k flash.
« Reply #21 on: November 21, 2020, 04:12:46 am »
Yes. That is what I'm not able to do yet. Looking at code for different MCU's and being able to know what it equals to other MCU's.
different registers.
T85 MCUSR  is the T4 RSTFLR
Learning to understand and how to type out " correct syntax " the settings
Should I type this
RSTFLR=0;       // Clear MCU Status Register
instead of
And type this to turn on the watchdog timer as a Interrupt
 WDTCSR = (0<<WDE)|(1<<WDIE) ;  // set watchdog in interrupt mode
page 49  Watchdog Timer Control Register
Table 9-2. Watchdog Timer Configuration table
I'm guessing it should be something like this
 WDTON = (0<<WDE) | (1<< WDIE) | (???????????
But looking at other code, it should be
   ; setup watchdog
   ldi temp, 0xD8 ; write signature
   out CCP, temp
   ldi temp, (0<<WDE)|(1<<WDIE)|(1<<WDP0) ; set watchdog in interrupt mode and 4k cycles
   out WDTCSR, temp
WDTCSR = (0<<WDE) | (1<<WDIE) | ( Again I don't understand what to put her for 8 seconds )
I'm not understanding what WDP[3:0] means so I know what to put in the last ( )
Like this  page 50   WDPn: Watchdog Timer Prescaler [n=3:0]    WDP[3:0]
It makes me think this is how I should write it
WDP = 1001
or
WDTCSR = (0<<WDE) | (1<<WDIE) | (1<<WDP0) | (0<<WDP1) | (0<<WDP2) | (1<<WDP3)
The 4 biniary WDP=1001 is the 4 WDPn registers ?
Maybe I should write it
WDTCSR = (0<<WDE) | (1<<WDIE) | (1<<WDP0) | (1<<WDP3)
Leaving out the 0's  (0<<WDP1) | (0<<WDP2)  because they are default 0. why tell a 0 to change to a 0. If it's already a 0 ?
Another thing. Would setting the WDTON configuration bit make the code any smaller ? Since the WDTON flag is watchdog timer always on ?
Sorry for the incorrect terms.
Man this is frustrating. I can look at mechanical things and figure out how it is working and what the names of the parts are. But looking at code is a whole new thing. I can see the mechanical with my eyes and almost work it out. This is more about using my minds eyes to connect how the words / terms are connecting with all the rest. I guess I also use my minds eye to work out mechanical, but having years experience makes it feel so naturally intuitive.
« Last Edit: November 21, 2020, 04:24:04 am by minipower »
« Reply #22 on: November 21, 2020, 04:46:18 am »
Should I type this
instead of
   ; setup watchdog
   out CCP, temp
   out WDTCSR, temp
WDP = 1001
or
I did notice that the Tiny 4 does not have ADC. Only the Attiny5 and 10 have it. But they all have the Analog Comparator.
So I do have.
in my setup
Offline sleemanj
« Reply #23 on: November 21, 2020, 06:50:30 am »
As I aleady said, your arduino code compiles fine for tiny4 with the modifications given, not tested but it looks like it would probably function correctly, and the WD aspect of it is pure AVR c with no arduinoism i think if You really don't want to code in Arduino.
As for the rest of your post that comes down ti "read and understand the datasheet", not just copy code without knowing what it dooes,  for example you ask "Should I type this RSTFLR=0;       // Clear MCU Status Register instead of MCUSR = 0;     // Clear MCU Status Registe"  well ask yourself what you are trying to achieve, if you don't understand **why** it is being done, then thats what you need to figure out.  and it's in the datasheet, hint, see the note about WE and how WDRF overrides it.
Offline admiralk
« Reply #24 on: November 22, 2020, 02:30:57 am »
As for the rest of your post that comes down to "read and understand the datasheet", not just copy code without knowing what it does.
This should have been in the first reply. When you walk away from Arduino you no longer have the luxury of everything being the same.  :-+
