Author Topic: help with detecting an electronics component  (Read 3514 times)
Offline m4rtinTopic starter
« on: September 24, 2015, 04:28:55 pm »
What kind of component is damaged on the image here? A SMD 20 ohm resistor?
Offline singapol
  • Country: sg
Re: help with detecting an electronics component
« Reply #1 on: September 24, 2015, 04:45:37 pm »
Looks like a PTC resistor 20 ohm?
Offline Falcon69
« Reply #2 on: September 24, 2015, 05:08:06 pm »
that is a resettable fuse. 200mA
Offline alsetalokin4017
« Reply #3 on: September 24, 2015, 08:51:10 pm »
Not any more!
« Reply #4 on: September 24, 2015, 10:42:01 pm »
How do you know that this is a resettable fuse? How do you tell a difference from SMD resistor? I mean what should I check in order to be able to identify the component next time myself. In addition, does 200mA mean that once the current is >0.2A, the resettable fuse is tripped and the resistance of resettable fuse will increase in orders of magnitudes?
Not any more!
:D
« Last Edit: September 24, 2015, 10:43:55 pm by m4rtin »
Offline AF6LJ
« Reply #5 on: September 24, 2015, 10:46:36 pm »
I agree it looks like a resettable fuse to me.
Sue AF6LJ
Online sleemanj
  • Professional tightwad.
« Reply #6 on: September 24, 2015, 10:52:26 pm »
It just looks like one, having the semi-circular cut outs on the end is common with smd PTC and with smd LED, it's not an LED.
A google image search gets us here:
http://uk.farnell.com/te-connectivity-raychem/microsmd005f-2/polyswitch-smd-1210-0-05a/dp/1345915
which is a 0.05A and has the same markings except the number, and if we apply that pattern we can see that yours is 0.2A
Yes and no.  It will require substantially more than 200mA to trip (or a smaller amount more for a longer period of time), but it can pass 200mA.  Take a look at the datasheet in the link above, in the performance ratings, you can see for that "50mA" fuse, it takes 150mA to trip it at 20 degrees ambient temperature, and the time to trip is 1.5 seconds at 250mA (20 degrees again), so you can see the overload needs to be substantial to get any meaningful trip-time.  It we are talking about a pure short circuit, no problem, a few amps is going to trip it in a flash, if we are talking about just drawing a bit more current than usual, you might be there for a long time waiting for it to go.
Offline DimitriP
« Reply #7 on: September 24, 2015, 10:55:08 pm »
Not any more!
:D
If you knew  the manufacture's logo , and that the company is poly switch and they are in the circuit protection business, you would have no trouble at all whatsoever :)
http://www.digikey.com/product-detail/en/MINISMDC014F-2/MINISMDC014FCT-ND/1045846
Offline DimitriP
« Reply #8 on: September 24, 2015, 11:05:29 pm »
Ok, I like that method better :)
Offline Falcon69
« Reply #9 on: September 25, 2015, 02:29:07 am »
Because I have lots of those exact ones in my Parts Bin.  They are made by TE Connectivity/Rachem.
http://www.mouser.com/ProductDetail/TE-Connectivity-Raychem/NANOASMDC020F-2/?qs=sGAEpiMZZMt8Ji9PfVTQzHcktPAFfzlpZFyge4QdWIE%3d
They are available in 9v, 12v, and 24v versions in 1206 and 1812 SMD size.
