Hi there,
I am trying to teach myself mpasm so I wrote a small program that was supposed to spin stepper motor one revolution in alternate directions.
I am using pololu breakout board for A4988 driver
However, my program just drives stepper non-stop in one direction. For some reason, it appears to be stuck in first loop and I can't figure out why.
I would really appreciate if anybody could point out mistake to me as I have been stuck with this for the past few days without success.
Thanks
list p=10F200 ; list directive to define processor
#include <p10F200.inc> ; processor specific variable definitions
__CONFIG _MCLRE_ON & _CP_OFF & _WDT_OFF
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
UDATA
dc1 res 1
dc2 res 1
RCCAL CODE 0x0FF ; processor reset vector
res 1
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
RESET CODE 0x000
movwf OSCCAL ; update register with factory cal value
start
movlw b'11111100' ; Set GP1 output (pulse) and
tris GPIO ; Set GP0 output (direction)
main_loop
movlw b'00000001' ; Set direction to 1
movwf GPIO
movlw .200
movwf dc2
loop_1
bsf GPIO,1 ;Set GP1 high
call delay ; 1 ms delay
bcf GPIO,1 ; Set GP1 Low
decfsz dc2,f
goto loop_1
movlw b'00000000' ;Set direction 0
movwf GPIO
movlw .200 ; 200 x 1.8 degree =360 degree
movwf dc2 ; One full rotation of stepper
loop_2
bcf GPIO,1 ;Set GP1 low
decfsz dc2,f
goto loop_2
goto main_loop
SUBS CODE
delay ; 1ms delay
clrf dc1
dly_1
nop
decfsz dc1,f
goto dly_1
END ; directive 'end of program'
