Sorry if this is a broadened sort of question, as well as any stupid questions I might ask.
Lately I have found myself having trouble trying to figure out what is wrong with a PCB.
When I got started with electronics, I got lucky with most repairs, but when it gets past a PSU recap or bad bridge rectifier it gets confusing for me. Right now I have quite a few projects in this sorta boat.
For instance, recently I got a circuit board that has four 7 segment displays, a z-80, a transistor array, etc.
It would freeze up a few seconds after powerup, or when any button was triggered. Figured it was the z-80 causing the freezing, so I got a new one, replaced it. When I tested the board right after the replacement, it worked a treat! the display lit up, and no freeze.
I put it all back together carefully, and then no display, but 2 single LEDs lit up.
I dont really know what to be looking for. I have an oscilloscope, but I have no idea what I should see on the z-80 pins, or many other IC's on this board for that matter.
I also notice people testing a trace with an ohm meter and being able to see if something is not "right" on that trace sometimes. Is there a standard in ohms that people are looking for on traces in question, or is there more to it? (surrounding components, etc.)
Also, I am confused on some through hole boards... on the empty inlets connecting both sides in places, I noticed some boards seem to have these filled with solder. Sometimes they are not filled. I see this, and think its a cold solder joint. Is this incorrect? Will an inlet that is empty still work for both sides? Are some empty inlets manufactured that way?
Again, I am sorry if these questions are poor, but I am truly puzzled with this stuff mentioned. Thanks ahead of time.
