I and few of my friends are designing a board for cansat. We decided to use Origin's Hornet ORG1411 as our GPS. We've assembled the board however GPS is not turning on.
GPS with its power supply.
Relevant part of the PCB.
R27 resistor is there to work as a jumper to select between auto and manual startup of the module. Tests were conducted on both configurations. Wakeup never gets high and reset is always low. Sending startup pulses to ON_OFF in manual mode also does nothing. We also tested two separate devices, both had the same problem. Measured voltage on power rail is 1.81V with 2mV pk-pk of ripple. Thanks for your help in advance!
