Author Topic: How do I figure out what this transformer does?  (Read 681 times)
Offline dongeoTopic starter
« on: September 25, 2020, 06:41:33 pm »
Hi guys, I've managed to pick up some toroidal transformers, but they've only come with labels with model number and manufacturer on them. I've tried googling and looking on their websites, but can't seem to find any record of them anywhere! Is there any way I can find out more info on these?
Here's a picture: https://pasteboard.co/JsKPWVU.jpg
« Last Edit: September 25, 2020, 06:49:33 pm by dongeo »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: How do I figure out what this transformer does?
« Reply #1 on: September 25, 2020, 07:39:16 pm »
Transformers can be tested, yes.
Quite possible that it's a custom part, in which case you'd have to ask the manufacturer or customer for a drawing.  Good luck with that...
The first steps are:
- Noting dimensions (height, ID, OD)
- Wire size if visible (should be able to guess at the outer layer, anyway, and figure out which color wires it's on)
- Number of turns if visible (pretty much N/A here)
- Measure DC resistance of each winding, including mapping out which colors are connected to each other
Then you can guess at primary, secondary, CT or multitap windings, etc.
Pretty safe to apply mains frequency, at low voltage (say from a 6.3V transformer?), to most any winding, and measure the other voltages.  This gets ratios.
Ideally, you'd do a saturation test as well, using a current-limited source (maybe a transformer with a series resistor) and an AC voltmeter.  Apply relatively high voltage to a probably-low voltage winding.  See where it starts dropping off: that is, as you increase ACV, the winding V will rise proportionally, until it starts to shy away (rising slower and slow) at some point.  That point is the onset of saturation, and is (more or less) the highest voltage that is reasonable to apply, at that frequency.
Finally, current rating of each winding can be guessed from overall size, and winding resistances.
Seven Transistor Labs, LLC
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #2 on: September 25, 2020, 10:04:25 pm »
A quick way to determine the approximate Volt-Amp rating is to weigh the transformer and then compare the weight against other transformers in manufacturer's catalogs.
If you have an LCR meter you can easily determine the turns ratio by taking the square root of the ratio of the two winding inductances.
Offline nachus001
  • Country: ar
« Reply #3 on: September 28, 2020, 02:16:09 pm »
If you have available an inductance meter you can check the primary's and secondary inductances.
Usually the primary inductance will be higher than secondary in a step down transformer.
If you can check for the wire sizes it will give you an idea  of the currents in every winding
