Hi guys, I'm new here, i'm trying to do switchless mod on my sega genesis and I have to program the pic16f676 with the .hex code. As I don't have the pickit3 i'm using the TL866II plus. The programming is successful but when i solder the chip on the board it doesn't work. I've add 2 files, the .c code and the compiled .hex file. Anyone could tell me if this .hex could be flashed with minipro? I have latest version xpro 10.15 software, but a friend told me that had same issue and seems there are some "initializations" problem with tl866II plus. I really need your help, thanks a lot!
