Author Topic: How Reflections are generated in unmatched transmission line?  (Read 3361 times)
Offline Kedar264Topic starter
  • Country: in
  • Listen to Your Voice
I perticularly want to know about joints in tratransmission line ,how sigals reflection occure at joints . Thinking a lot ...  :palm:
Please let me know Any related contents .
Offline miguelvp
Re: How Reflections are generated in unmatched transmission line?
« Reply #1 on: May 24, 2015, 06:23:06 am »
These two videos might help:
Offline hamster_nz
« Reply #2 on: May 24, 2015, 06:42:18 am »
Watch  and understand...
Oldie but a goodie
Offline AlfBaz
« Reply #3 on: May 24, 2015, 06:47:23 am »
you can also have a look at this previous thread
https://www.eevblog.com/forum/chat/how-are-signals-reflected-in-a-wire/
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #4 on: May 24, 2015, 06:53:45 am »
I would suggest studying the first 5 hits on Google.
https://www.google.com/search?q=pcb+transmission+line&ie=utf-8&oe=utf-8#q=transmission+line+reflections
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline Rupunzell
« Reply #5 on: May 24, 2015, 07:40:51 am »
Adding a bit of math and theory.
Spend the time to watch lecture series 5, then lecture series 6. This will give some foundational knowledge to how this transmission line stuff works.
Bernice
Offline miguelvp
« Reply #6 on: May 24, 2015, 08:21:56 am »
Oldie but a goodie
I love those wave machines.
Offline Jeff1946
« Reply #7 on: May 24, 2015, 08:02:32 pm »
You may want to check out this web site on vibrations,
http://www.acs.psu.edu/drussell/Demos/reflect/reflect.html
to compare a wave on a string to a transmission line.  Note how the wave is inverted with a hard reflection (transmission line shorted) vs a soft reflection (transmission line open).  With perfect termination, typically 50 ohms, there is no reflection as if the transmission line went out to infinity.
