You just heat the thing to a target temperature and make sure there is at least some liquid water in the generator, steam comes out at a pressure dependent on the generator temperature.
As you draw steam, more water boils, reducing the temperature and causing the heaters to add more heat, steam pressure is (for saturated steam) related to generator temperature by a simple curve (100 celcius = atmospheric pressure, 150 celcius = 4 bar, 200 celcius = roughly 14 bar), set the temperature and (as long as there is liquid water in the boiler) you know the pressure.
Regards, Dan.
