I'm designing a board to be able to drive 12V powered electronic locks. Now not having the ability to precisely define the type of electronic lock used and its specifications I have doubts about the design. I would like to eliminate the noise that are generated when soilenoids are handled, e.g., EMF backs, etc., which could reset a MCU.
So I had in mind to opto-isolate the outputs, but that would be quite unnecessary since my purpose is to use one power supply to derive the supply voltages for MCU and auxiliary voltages and the solenoid supply. I thought an isolated DC DC converter might be a solution, but it is too expensive. The solenoids are driven by a ZXMS6006DGQ-13, and the maximum current available will be 1.5A.
Does anyone have any ideas?
