The title is a bit misleading, so allow me to explain. It seems like chips/ICs come in many varieties even if they are in the same series. I don't understand why a chip has versions with slight variations in the model number or what these changes mean.
For example, a PCB I am working on has a SN74LS139N chip. Pasting this into Digi-Key gets me nothing. However, if I paste SN74LS139 (we removed the "N") a few different chips pop up. Many of these chips appear to be in the same series, but that does that necessarily mean they are compatible?
Another example is a chip labeled LH5168FB-10L. Pasting this into Digi-Key gets me nothing, but if I simply type LH516 then I a few SRAM units pop up that may work. Yet, like before, I cannot tell if these will work as a replacement for my current chip.
I would sum up my questions as so.
- How do the naming conventions of chips work?
- How can you tell if a chip is a suitable replacement?
