Gettin back to the topic of probing mains, and the nasties on it I have always had a few dozen plugtops with a VDR in them across live and neutral, simply as a plug to occupy a spare outlet, preferably the first in a strip. This has worked well to attenuate spikes for me, and I also have collected a lot of surge supressor plugtops over the years ( thanks to our Telecom supplier who will often simply change them out if they cause tripping of EL breakers due to surges, often replacing with a regular plugtop as well) and as they also have 3 VDR's in them between pins they also work well. Phone lines also have transient suppression as well, and though this may not be the best for ADSL ( adds to loss so I modify them to leave only the spark gap and remove the silicon switch inside, but have a unmodified one after the ADSL filters) It did save all my electronics when lightning hit a building 50m away a few years ago. Neighbours lost TV sets and electronics, I had no damage at all aside from tripped power. I did have some VDR units go short circuit a while later ( they did the job though) and it was a few minutes work to find the faulty one and simply replace the VDR inside.
I did recently buy a Thermaltake PC power supply, and see that they did a very interesting thing to clip spikes, by using instead of a VDR a spark gap. Hope the fusing is good, though I think those will need the warranty voided if it does operate to replace the fuse. I do not think the NTC thermistor will cope well with being used to current limit the mains, they tend to catch fire and burn in that application. I have done that before......., but it survived slightly crispy and still works even though it is now pacman shaped.
