Author Topic: How to preserve tin paste?  (Read 969 times)
Offline Adrian_Arg.Topic starter
  • Country: ar
« on: February 07, 2021, 03:43:39 pm »
About two months ago I did a job with paste tin, this was new, today I am going to use it and it is hard, it was well covered and in a cool place, does anyone know what it is revived with, with alcohol?
D-NQ-NP-956804-MLA31063457007-062019-O" border="0
« Last Edit: February 07, 2021, 03:46:30 pm by Adrian_Arg. »
Offline mvs
Re: How to preserve tin paste?
« Reply #1 on: February 07, 2021, 04:18:43 pm »
Make it warm and add some gel flux, like RMA223 or NC559.
For the next time, i would rather recommend you to buy paste in a syringe.
Glycerine may also work well, except that it needs to be cleaned.
It is great surface tension modifier for solder. I use it for tinning tracks on self made PCBs.
« Last Edit: February 07, 2021, 04:55:46 pm by mvs »
The following users thanked this post: perieanuo, Adrian_Arg.
  • Country: ar
« Reply #2 on: February 07, 2021, 04:48:59 pm »
ok, thanks to the two
Offline strawberry
  • Country: lv
« Reply #3 on: February 07, 2021, 09:52:52 pm »
Flux and solder in room temperature may separate and left/leak on syringe internal walls, therefore solder paste will bee too thick to get it out easy
Offline tooki
« Reply #4 on: February 08, 2021, 06:57:12 am »
Skip the low temp ones (SnBi/SnBiAg) from ChipQuik, their flux formula is garbage and won't activate before alloy melting.
For what it’s worth, I’ve had no trouble with the low-temp ChipQuik — at least not with fresh components and PCBs. I haven’t tested it with older, more oxidized parts.
Offline tooki
« Reply #5 on: February 08, 2021, 11:12:39 am »
Ah ok! I’ve tried their regular low-temp, and no-fridge regular temp, but not the combination!
Offline jmelson
« Reply #6 on: February 08, 2021, 09:30:41 pm »
If you can get butanol (the 4-carbon alcohol) it is a low vapor-pressure solvent that seems to be the magic ingredient in many pastes.
I managed to get a bottle of it, and add just a few drops to the paste any time it seems too stiff.  Then, you have to stir it in real well.
Jon
The following users thanked this post: Adrian_Arg.
  • Country: ar
« Reply #7 on: February 08, 2021, 11:10:30 pm »
I'm going to see if in this blessed city it is achieved!
