Author Topic: how to safely take measurements with oscilloscope??  (Read 8835 times)
Offline kasumykuTopic starter
« on: June 21, 2013, 05:46:04 pm »
Hi everyone,
Already looked thru posts and watched a lot of vids trying to get as much info as possible regarding oscilloscopes but there is not much about SAFETY!!!
English 2nd language so I hope you'll understand my question,also im 1/2 way into electronics technician course so I'm still a newbie.
Just bought my first oscilloscope and I'm still afraid of short circuits!!!
I understand the way grounding works(thanks to Dave's video and Google) and if attaching ground clip to positive you'll get a nasty shock or even wors, and that's because neutral and ground are connected together so you form a very nice loop :)
SO my question is : HOW TO SAFELY PROBE YOUR CIRCUIT?
Maybe it sounds stupid (once again still a newbie) but beforeprobing should multimeter be used to check for polarity, or what advices can I get from more experience guys like you.
Thanks!!!
Offline c4757p
  • adieu
Re: how to safely take measurements with oscilloscope??
« Reply #1 on: June 21, 2013, 06:01:03 pm »
To put it simply, look for return paths. For current to flow in a short circuit, it must have somewhere to flow back. If there are no return paths (the device under test is powered by a battery, or an isolated lab supply), you can stick your probe anywhere, because there's nowhere for current to flow.
Keep in mind that once you stick that probe somewhere, it becomes a return path for the second probe, so you will then need to exercise care when connecting channel 2.
If there is a return path, you must not connect the ground lead to a voltage that is different from the oscilloscope's ground, because a voltage difference across the wire will cause current to flow.
Don't probe mains.
Offline WBB
« Reply #2 on: June 21, 2013, 06:11:55 pm »
Checking the test points with a multimeter before attaching a scope is an excellent practice. Even more so if the DUT is plugged into mains. Checking the voltage between the bnc jack on your scope and the point on your circuit you are about to hook the scope ground to can prevent a nasty surprise.
« Reply #3 on: June 21, 2013, 06:33:29 pm »
Thanks guys for such a quick reply! So after all is good to test polarity with DMM before probing, at least until I become more knowledged about scopes and electronics in general...
Offline c4757p
  • adieu
« Reply #4 on: June 21, 2013, 06:39:49 pm »
Well, remember what I said about return paths - if there is no return path (which will happen most of the time!), your DMM may not read zero and yet it will still be safe to connect. You need a DMM with a "low impedance" mode to really check this. Otherwise, manually put it into a high range (at least one above the 2V range), and hold the probes there for a minute and see if the number slowly drops. (The range is because some  meters have an extra high impedance on the low ranges.) If the number jumps around as you move the probes, you're probably OK. This is because there can be capacitance between the device and ground, which is charged up, and the meter will read this and make you think there's a voltage between them. Technically there is, but it will go away as soon as you make your connection and discharge it.
The best way is to know the circuit and think about whether there is a path for current to be conducted. Obviously the ability to do this comes with experience, but you should start trying to develop that.
Online IanB
« Reply #5 on: June 21, 2013, 06:40:06 pm »
Simply put:
1. The circuit you are testing must be isolated. It should be powered from an isolated lab power supply or batteries.
2. If using two or more probes, never connect the ground clips to different parts of the circuit.
3. As others have said, check voltages with a multimeter before probing them.
Offline edavid
« Reply #6 on: June 21, 2013, 07:00:48 pm »
This is misleading.  It is normal for the circuit being tested and the scope to have a common ground.  You can then probe any part of the circuit safely, except the primary side of a line operated power supply.  What you can't do is connect the scope probe ground clip to anywhere except another ground point.  If you need to be able to do that, then yes, you need an isolated power supply.
Online IanB
« Reply #7 on: June 21, 2013, 09:25:34 pm »
I accept your point, except that for a beginner this might be an unwise working practice. It is very easy to absent-mindedly clip the ground clip to a part of the circuit you want to measure, forgetting that it is not an isolated DMM probe. If you clip it to the wrong place you could let out some magic smoke or worse. I have done this myself and was only reminded I was being dumb when sparks flew from the ground clip.
Offline eKretz
« Reply #8 on: June 21, 2013, 09:26:49 pm »
I recommend that beginners check with a multimeter first if there is any question in their mind. I even still do this from time to time to be safe if I'm unfamiliar with a circuit/device.  What the others are trying to tell you is that you can probe your device safely, you just need to watch your grounds. Sometimes ground isn't ground, you see? LOL. There's mains earth and there's device ground, and they are not the same. Many circuits have both, and they can not be safely interchanged when probing. You really ought to consider using an isolation transformer for your devices under test also.
Offline edavid
« Reply #9 on: June 21, 2013, 09:35:27 pm »
On the other hand, if the circuit is isolated, the beginner might forget to connect the scope ground at all, and then be confused by seeing AC line leakage everywhere  :(
Offline c4757p
  • adieu
« Reply #10 on: June 21, 2013, 09:41:17 pm »
Sure, but "remember to connect the ground lead" is right up there with "remember to set the timebase". It doesn't really belong in a discussion of safety, it's equally as basic as "turn on your oscilloscope".
« Reply #11 on: June 21, 2013, 09:45:22 pm »
The beginner got confused now  |O
Offline c4757p
  • adieu
« Reply #12 on: June 21, 2013, 09:47:54 pm »
:) Easy to do, don't feel bad. What exactly is confusing you?
« Reply #13 on: June 21, 2013, 09:54:38 pm »
Let me know if I understood wrong what you explained...
If both,device under testing and scope share same ground then HOW can you probe any part of the circuit safely?
My example was: what if ground clip touches by mistake a voltage difference , then ....booom
Once again, sorry but maybe I understood wrong your explanation...
Offline c4757p
  • adieu
« Reply #14 on: June 21, 2013, 10:03:00 pm »
The two must share a common ground or else you won't get a proper signal - but if they don't already share one, the ground clip will establish one. If they already share a common ground through some other means, then attaching the ground clip to something in the circuit that's not ground will short that point to ground. You can still connect the probe, you just have to connect it to a ground point.
Even if they don't share a common ground, there can still be a voltage between them. This voltage is stored in the capacitance between the device and the oscilloscope - you can see it with the voltmeter, which is why the DMM isn't always the best way to check, but once you connect the ground lead, the voltage on that capacitance will go away.
Sorry if it's still confusing. There is a lot of information to take in at once here.
Offline vk6zgo
« Reply #15 on: June 22, 2013, 04:23:54 am »
If it is just that you touched a 5v supply rail or similar in the equipment,you now have given the unit a new fault
If the DUT does have a designated "ground",it is probably connected to any metal frame of the device,or on a PCB,a large area of copper.
If the internal "ground" is connected to the Mains supply Earth,you can actually check various points for the presence of voltage with respect to ground using the probe with the ground lead/clip disconnected,(removed),as the Oscilloscope power cable provides the necessary return path to Earth.
If a voltage is present,you know you can't put the ground clip on that point! :D
If you need to critically check waveforms at various points,obviously having several tens of metres of wire between the two Earth points will not give you the best results,so once you have determined the "ground"of your DUT,clip the "ground" clip to that & take all your measurements with respect to that point.
 NOTE:I have used the terms "Ground" AND"Earth",as in the DUT,"ground" may simply be a "common" rail with no connection to the Mains Supply "Earth" (or any other part of the Mains).
When the "ground" & "Earth" are connected they become the same thing.
Sometimes it would be nice to see the voltage across a component where both ends are above ground,but this can be calculated if you know the voltage at both ends,or you can measure both ends at the same time w.r.t ground using two channels & use the A-B function on your 'scope.
If,for any reason,you need to probe the Mains supply,use the "no ground clip" method described above.
WARNING: Not all probes are rated to look at Mains supply voltages,so you will need to be sure of this.
It is probably better at this  stage if you leave this till you are more experienced.
« Last Edit: June 22, 2013, 04:27:11 am by vk6zgo »
« Reply #16 on: June 22, 2013, 02:53:42 pm »
MAybe it sounds stupid but what about this situation:
Ok, so what if you do the same mistake but the other way around...
Like, both DUT and SCOPE have a common ground and by mistake you put your SCOPE probe ( not ground clip) to  the DUT ground, would it happen almost the same thing, like wouldn't short the SCOPE? because it also creates a path the other way around, it's like attaching the ground clip to the probe...
Does anyone know a good book about oscilloscopes and how to take proper measurements so not to bother you guys anymore. :D
Offline c4757p
  • adieu
« Reply #17 on: June 22, 2013, 03:19:36 pm »
You're not going to get a short through the probe tip because the oscilloscope input has a very high impedance (1 megohm). There is a current path, technically, but it's only going to conduct a few microamps. Obviously you do have to respect the maximum voltage of the scope input (typically around 250-300V).
« Reply #18 on: June 22, 2013, 03:29:19 pm »
Thanks for clearing things up, obviously I need to do a lot of research before I do anything stupid!
As requested before, DO YOU GUYS KNOW A GOOD BOOK ABOUT OSCILLOSCOPES AND HOW TO TAKE PROPER MEASUREMENTS?
Thanks!
Offline c4757p
  • adieu
« Reply #19 on: June 22, 2013, 03:31:24 pm »
NO I DO NOT!
But I do know how to solve that problem - I think your shift key is stuck. Check it for gunk underneath; clean with alcohol.  ;)
Offline dr.diesel
« Reply #20 on: June 22, 2013, 03:36:39 pm »
Will this work:
Offline c4757p
  • adieu
« Reply #21 on: June 22, 2013, 03:38:00 pm »
The best part is that I almost called it IPA for isopropyl alcohol, in which case you still could have used that picture  ;D
Sorry, kasumyku, for being a prick on your thread, I'm in that kind of mood... Most of us didn't learn this from a book. Just play around. Seriously, as long as you respect the few basic rules we've established here, and you don't go waltzing about near mains voltage, you're not going to blow up your scope.
« Last Edit: June 22, 2013, 03:40:18 pm by c4757p »
« Reply #22 on: June 22, 2013, 03:50:50 pm »
 :-DD you are not being a prick, but that was a good one,btw just fixed it, look actually its even better now!
thanks guys for all your advices!!!
Offline vk6zgo
« Reply #23 on: June 22, 2013, 03:52:42 pm »
If both the DUT & the 'scope have the same ground,there is no potential difference between the grounds of the two devices.
If you place the probe on the DUT ground,it is the same as touching the ground of the 'scope,so you will be looking at zero volts,& as the probe is not a source of current,there is no "path the other way round".
Offline dr.diesel
« Reply #24 on: June 22, 2013, 03:53:35 pm »
btw just fixed it
BTW, which IPA did you use?
