Dear All,
I have a question regarding the transformer used in this schematic.
The transformer is specified as 15 turns, 0.6 mm × 3 bifilar winding. I understand that a bifilar winding means two windings are wound together using parallel wires, but I am confused about the winding polarity and the terminal connections shown in the schematic.
Could anybody please help me understand how to physically construct this transformer?
Specifically, I would appreciate guidance on:
1)How to wind the 15-turn, 0.6 mm × 3 winding.
2)How many individual wires should be used during winding.
3)How to identify the start and finish of each winding.
4)How to connect the terminals so that the polarity (dot convention) matches the schematic.
If anyone has a winding diagram, photographs, or a reference video showing a similar transformer, I would be very grateful.
There is something fishy about the way they drew that transformer and the dots. The dots are supposed to indicate the SAME polarity for each terminal. For that transformer, if the input dotted end is positive then the output dotted end is also positive, there is no flip of polarity as the seem to be indicating.
As to the physical wires, the two dots would be the two starts of a 2 wire bifilar winding (simplest view) but you could also refer to them as the two 'ends' or 'finishes' it doesn't matter because the polarity will always be DOT POSITIVE, DOT POSITIVE, and if you have three wires all the dots are the same polarity. You could refer to them as DOT NEGATIVE and DOT NEGATIVE but that doesn't change anything, and thinking about it in terms of dot positive is just easier to think about. There is no time when you will see DOT POSITIVE and DOT NEGATIVE on the same transformer though as they seem to be indicating. They either made a mistake or they are trying to indicate some other operational mode, which doesn't make sense though so they probably just made a mistake.
Now as to the operation of the circuit itself, you have to figure out if they reversed the positive/negative labeling or they reversed the dots. It could be that they made a mistake in labeling the dots positive and negative, or they should have put one of the dots on the bottom terminal not the top. The circuit depends on the right polarity of the wiring. If the wiring is not right the circuit probably won't work as intended. We could look into that also.
So the bottom line is not where the dots are or what the polarity is on the schematic itself, it is what the requirement of the circuit is. If the output of the transformer has to be in phase with the input then both dots should be drawn on top as shown, but if the output has to be flipped then one dot has to be drawn on the bottom terminal. The required phase is determined by the circuit operation.
You can wind 3 turns bifilar it's just three wires instead of two. All of the starts will have the same polarity, and they will all have the opposite polarity as all three of the finishes.
I just took another look at your schematic. It looks like a flyback topology.
Because of that, the output expects to be REVERSED when the MOSFETs turn off. That means that the schematic markings (+) and (-) are indicating the period where the output diodes conduct thus producing an output voltage or an increase in output voltage. That means the dot on the output of the transformer should have been drawn on the BOTTOM not on the top, and the input side the dot is correct being drawn on the TOP terminal.
This works because we don't want an output when the MOSFETs turn on, we want an output when the MOSFETs turn off. When they turn on, the top input terminal of the transformer goes positive and the bottom negative, and with the output winding reversed the top then goes negative which prevents the diodes from conducting. Then when the MOSFETs turn off, the primary voltage reverses, meaning the top terminals goes negative, and with the output winding reversed that means the top terminal of the output winding goes positive, and that then produces an output current which increases the output voltage.
If we draw the dot on the output of the transformer on the BOTTOM terminal, the schematic should be correct then.
See new drawing.
