Just got another LED driver with the LC6640. There's not much info out there,
so I thought I should add what little I found.
Info from this page:
https://en.eeworld.com.cn/bbs/thread-1253612-1-1.htmlLichiwei LC6640 SOP7 high-precision flyback LED constant current driver chip
supports full range 85~265Vac
The original agent of Lichi Micro LC6640 is a high-precision flyback LED constant
current driver chip. The chip works in the inductor current discontinuous mode and
is suitable for isolated flyback LED constant current power supply with a full range
of input voltages from 85Vac to 265Vac. The chip uses patented demagnetization
detection technology and high-voltage JFET power supply technology, without the need
for VCC capacitors and startup resistors, making its peripheral devices simpler and
saving peripheral costs. The chip has multiple protection functions, including LED
short circuit protection, open circuit protection, chip temperature overheating
regulation function, etc. LC6640 uses SOP7 package.
Features:
◆ No VCC capacitor, no startup resistor
◆ Integrated high voltage power supply function
◆ No need for auxiliary winding detection and power supply
◆ Wide input voltage range
◆ ±5% LED output current accuracy
◆ LED short circuit protection
◆ LED open circuit protection
◆ EN function
◆ Chip power supply undervoltage protection
◆ Overheat regulation function
application
◆ LED bulb
◆ LED downlight
◆ Other LED lighting
From this page it looks like the circuit topology is "PSR DCM", it has a 0.5 power
factor and that it works up to 40W (100-264Vac) or 48W (175-264Vac):
https://www-lichiwei-com.translate.goog/product.php?id=7&_x_tr_sl=zh-CN&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=sc&_x_tr_sch=httpPictures are from the first link.
