Author Topic: I need help with wirin g a switch  (Read 2680 times)
Offline HextejasTopic starter
« on: September 02, 2023, 02:59:29 pm »
The switch is a Westek 758FPCT and dumb old me took a picture of the inside of the box but got the wrong side of the wires.
So here goes:
The switch has 3 wires labeled as such
1) Red-Load
2) White-Neut
3) Black-Line
and the box also has 3 wires colored as:
1) Green
2) White
3) Black
I have been told to wire accordingly:
White to White
Black to Black
and
Green to Red
What say you all ?
and thanks
Did I say that electricity scares me ?
Offline donlisms
Re: I need help with wirin g a switch
« Reply #1 on: September 02, 2023, 03:27:58 pm »
Electricity *should* scare you!
(Sorry I don't have an answer.)
Offline BillyO
« Reply #2 on: September 02, 2023, 06:00:09 pm »
Can you post good detailed pictures?
It does not sound right to me.  In the US green is normally ground.  Does the green wire go to the light you intend to control?
Here is a PDF that shows how it is to be used.  https://www.gtsanders.com/UserFiles/septemberdocuments/758CT_INSTRUCTIONS.pdf
« Last Edit: September 02, 2023, 06:03:28 pm by BillyO »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
« Reply #3 on: September 02, 2023, 08:16:25 pm »
Topic solved. I got help from an electrician friend of mine.
Offline BillyO
« Reply #4 on: September 02, 2023, 08:50:58 pm »
Best way to go anyway.  What did the solution turn out to be?
