Well, of all 6 outputs, 4 of them go to 0V and two remain at 1.01 volts when I set the current to 0mA. The two that remain at 1.01V say "On UR".
Ok, so I set a pot to 100 ohms. I set one of the so called bad channels to 0V and 0mA and one good channel to the same. The good channel measures -1mA and the bad channel measures 8uA. You are saying this is ok?
If I set the current to anything but 0A, no matter what voltage I set it to, it's always 0.01 volts higher than what I am setting. This is fine? Ugh, I don't don't like that. I'm to much of a perfectionist to be ok with that. I'm suppose to call Rigol when they open. This is what tequipment told me to do first. Should I even call them now?
