Author Topic: ideal diode (precion rectifier) with voltage follower in feedback?  (Read 4088 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
What is the point of adding a voltage follower into the feedback loop of a precision rectifier?
Output -> Diode -> Voltage follower (buffer op amp) > negative opamp terminal
Does this have something to do with improving the response time of the circuit?
http://upload.wikimedia.org/wikipedia/commons/6/60/Op-Amp_Precision_Rectifier.svg with a buffer in the feedback loop after the diode
the diode is a 1n4248
does this allow you to use a crap diode at the expense of an amplifier?
« Last Edit: July 19, 2013, 01:42:33 am by SArepairman »
Offline Odysseus
Re: ideal diode (precion rectifier) with voltage follower in feedback?
« Reply #1 on: July 20, 2013, 07:21:23 am »
Is the attached schematic what you're thinking of?
If so, I don't think it's going to improve the transient response of the amplifier since the first op-amp is still going to go open loop and enter saturation.
The only benefit I can see is the prevention of any subsequent circuitry from offsetting the voltage at which it rectifies.
Offline KJDS
    • my website holding page
« Reply #2 on: July 20, 2013, 09:13:50 am »
Dave did one of his videos on this a few weeks ago, might be worth a check.
« Reply #3 on: July 23, 2013, 10:41:12 am »
so it would remove the offset error created by  the next op-amp in line?
wont the voltage followers offset cause an offset anyway?
Offline Odysseus
« Reply #4 on: July 24, 2013, 03:44:16 am »
The precision rectifier goes flat when the current in the diode drops to zero.  The issue is if your load has a significant bias current.  Then the point at which the diode current is zero is no long the same as zero voltage.  The extra op-amp is just a buffer to prevent this.
This doesn't really explain why the second op-amp is inside the feedback loop of the first.  I see no advantage.
« Reply #5 on: July 24, 2013, 07:13:36 am »
this is the digitizer circuit on a spectrum analyzers video signal if it makes any difference.
looks like a peak detector circuit
