Author Topic: Identity of this component that caught fire so I may curse at it properly  (Read 3065 times)
Offline PurduephotogTopic starter
Just had an event.  Swore I heard chirping... Figured out eventually it was the UPS. Many words used.
What is this component that appears to have melted and vented? The relays are shot too... Figure that was the plastic smell.
Fuse intact, the GFCI outlet that fed it tripped. Smoke alarm didn't trigger.
Offline ataradov
    • Personal site
Looks like a capacitor. See what the remaining labels say.
Alex
Yeah... Soon as I can stand the smell. Breathing is still tough.
Looks like it was a cardboard tube with actual leads and one of which went thru what looked like a current sense.
I'll try for a better photo later. Just pissed off.
Offline David Hess
  • DavidH
It is a plastic film capacitor but I do not think it is part of differential (X class capacitor) or common mode (Y class capacitor) interference suppression because of that AC current transformer.  Instead, I suspect it is the series capacitor in a resonate switching converter.
Offline fonograph
  • Country: at
What is that device? What year was it manufactured?
Offline David Hess
  • DavidH
Based on the visible date codes, it was manufactured in the second half of 1995.
Offline onesixright
 :wtf:, looking at the components around the cap (?), guessing, it got freaking hot!
Offline Gyro
Yes, definitely a plastic film capacitor, too big to be an X cap. Possibly to try to clean up the output waveform of the UPS. It's not a moisture sensitive Rifa metalized paper so those comments don't apply. It has maybe suffered an overstress (instant or over time) which has caused it to self-heal itself to death.
If you're lucky, you may be able to read the value but given that you will need to replace the melted relays etc. and de-carbonize the PCB, it is probably beyond reasonable resurection.
Edit: Looking at the amount of metal, it may even be a film and foil type (non-self healing) rather than metalized film.
« Last Edit: October 17, 2017, 08:47:49 am by Gyro »
Best Regards, Chris
Offline stj
if you fix it, make sure you use a very high current replacement.
i know they make them for solar devices.
Offline NivagSwerdna
C6 looks a bit absent.  Crack in relay and is that other relay really as melted as it looks?
Re: Identity of this component that caught fire so I may curse at it properly
« Reply #10 on: October 17, 2017, 04:54:18 pm »
If by melted you mean slumped over and oozing like a classic surrealistic painting, yes.
The second ups plugged into the outlet was dead battery. The big one (pictured) was flashing. It may have still been supplying power... I don't know.
No I probably won't try to fix it. Burned all the way on the backside too. Fr4 is shot in that area.
I'll salvage the big transformer and the mosfets... Or at least the sinks... But I think it's headed to the recycler.
Batteries read 13.6v when I ripped them out.
Offline Karlo_Moharic
  • Country: hr
« Reply #11 on: October 17, 2017, 06:51:04 pm »
Axial electrolytical capacitor
The following users thanked this post: Purduephotog
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #12 on: October 18, 2017, 08:08:01 am »
Yeah, its a cap..it has foil all over the place.
This should be featured on EEVSmoke :) ;D
By the way, @Karlo_Moharic I thought you were Simon for a while. Hehe
Don't mess with an Electronics Engineer, it Megahertz!
Offline Gyro
« Reply #13 on: October 18, 2017, 08:33:38 am »
Nope, sorry. An electrolytic would vent through the end with the seal. That one is plastic encapsulated, no Aluminium can.
Best Regards, Chris
« Reply #14 on: October 21, 2017, 01:42:25 am »
It certainly smoked- the whole house reeked for a day until I got the fumes dissipated.  Has convinced me to install one of the big 8" turbo fans I have out a window, such that I can vent the house.  Oh well, another project.
In all honesty, thanks everyone for the help.  I've mailed APC; they requested photos, I've sent them, no followups since then.  Really just wanted to know what happened, if it was a known issue, and whether or not to junk any/all other units I've got or do PM/replacement on them.  It's hard to find good UPSs at decent prices (for a reason, I know).
The main unit was going to be rewired to work off a flooded marine battery with 200AH capacity.  Power the VOIP, phone, modem, and router.  I'm going to be rethinking that for a bit and include some sort of firesupression or chemical fire retardant in an easily disintegrate bag (if fire, dump fire suppressant).
Offline Gregg
« Reply #15 on: October 21, 2017, 02:27:35 am »
Fire suppressant can get awfully messy, especially the white powdered stuff that becomes conductive as soon as some moisture gets to it.  A CO2 fire extinguisher would be a better bet.  Halon used to be an option, but is frowned upon by environmentalists.
What you need is an emergency power off switch (EPO) that will disconnect both the battery and line in.  Without power to sustain the fire, circuit board fires usually don't burn too long; the smell is another issue.
