Author Topic: Interfacing a microcontroller serial with a FTDI usb device  (Read 8075 times)
Offline sean87Topic starter
  • EE WannaBee
    • EMBEDONIX
« on: December 13, 2012, 10:26:43 pm »
Hi guys,
I have one of these babies. When connected to PC, it is being recognized as a serial port. (It is a TI MSP430 that comes with FTDI chip)
http://inst.eecs.berkeley.edu/~cs194-5/sp08/lab1/telosb.JPG
Can I wire directly to the USB port and connect it to a microcontroller? I mean it should be connected to a real usb port to work as a COM port, or if I wire up to usb lines of it (Well this is using a FTDI chip) will it work as a TX/RX ?
If not, I think if I find the TX/RX pins of its microcontroller and connect that pins to PIC?
EMBEDONIX - Embedded Systems, Linux and good stuff!
Offline Psi
Re: Interfacing a microcontroller serial with a FTDI usb device
« Reply #1 on: December 13, 2012, 10:37:30 pm »
no, (well, not easily), you'd need to write a USB layer and driver in software on the micro so it could talk USB to the FTDI chip.
There's no point in doing that, its extremely complicated for no real reason.
Ah, do you mean if you have a second FTDI chip and wire them usb->usb ?
na, i'd be very surprised if that worked.
AFAIK the chip is a usb device only, it can't function as a usb host.
For USB to work there must always be a host and a device.
Yes, that should work fine, but you'll probably want to disconnect the existing microcontroller TX pin.
Otherwise your PIC will try and fight with it.
Although, i guess it may work without that as long as the existing micro is in reset state (not running) since the pin probably goes to highZ in that state.
Also you'll want to check the logic levels of everything involved to make sure you're not trying to push 5V into a 3.3V device, or to handle it if you are.
« Last Edit: December 13, 2012, 10:45:06 pm by Psi »
  • EE WannaBee
    • EMBEDONIX
« Reply #2 on: December 13, 2012, 10:47:27 pm »
Thanks, I guess I would try to find the UART pins of MSP430 that goes into that FTDI chip and hijack it right there.
The pic is 5v and this MSP430 is 3.3 I guess. I would need a converter also.
Hope it works! But finding and soldering wires to that tiny chip is a HOLAPOLA work.
Offline Psi
« Reply #3 on: December 13, 2012, 11:12:10 pm »
For a hobby project you can feed 3.3V into a 5V micro input and it will be quite happy.
For the 5V output you just need a 3.3V zener diode and a resistor to level shift 5V to 3.3V. (Or if you want to be ultra cheap you can get away with just a ~10k resistor in series between the 5V output and 3.3v input. That's really bad practice though)
yeah, it can take some skill.
« Last Edit: December 13, 2012, 11:17:31 pm by Psi »
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: December 13, 2012, 11:13:18 pm »
ftdi has a usb HOST controller now as well. so you could slap that on the other side to go usb to RS232 ...
Offline Psi
« Reply #5 on: December 13, 2012, 11:14:08 pm »
Interesting, is that a new chip or new firmware for existing ftdi chips?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: December 13, 2012, 11:26:45 pm »
Vinculum VNC2 - microcontroller with USB host.
However there are also some PICs with USB host at similar prices and more package options (Pic24FJxxGBxxx), and full source code for all the USB stuff.
Day Job: Mostly LEDs
  • EE WannaBee
    • EMBEDONIX
« Reply #7 on: December 13, 2012, 11:36:35 pm »
Well thanks mike but thats far beyond my knowledge :D hate using USB ...I spent couple of month running usb on PIC18F4550 and it was waste of time :( The microchip documentation is evil toward rookies.
I just did the soldering and HOLA...I could make the connection.
Now there is one big problem.
The MSP430 is internally programmed to send the data at 115200 baud rate. and the pic is programmed to receive at 57600 baud rate. Well I checked with scope and I receive at 115200 a meaningful signal.
Is there any baud rate converter/buff IC out of the shelf that can input 115200 and output 57600?
« Reply #8 on: December 14, 2012, 01:04:22 am »
no its not the vinculum ! that is a different beast.
FT313H Host controller.
and there is one specifically for Android platforms : FT311D
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: December 14, 2012, 01:51:57 am »
why dont you buy a $5 FTDI USB->Serial module it should be more suitable for generic mcu use. saving your baby, its look more usefull for other stuff. or if you want to salvage the ftdi chip to make a usb-serial converter, there's schematic online or from datasheet on how to do that.
if you are talking pc usb port... ftdi chip is meant to connect directly to it.
there must be 5V-3.3V regulator on board. bypassing the regulator should get you to the native usb 5v.
yes. but i'm not sure what ftdi chip is that, i assume its the normal pc usb to serial chip.
yes but please disconnect the pin from original mcu first?
above all, get the datasheet for the said ftdi chip first and study it.
Offline T4P
  • Country: sg
    • T4P
« Reply #10 on: December 14, 2012, 04:34:31 pm »
The STM32 L1,F1, F2 and F4 series have documented USB protocols ...
However only certain STM32s have USB FS
STM32F102 onwards only, 100 and 101 have no USB support
