I'm trying to connect to the I2C bus in the PM2525. I've extended the lead which goes from the main board to the display board so that it goes to a breadboard in the middle and the meter works as it did before. Now if I connect the SDA & SCL lines to an Arduino the PM2525 keeps resetting. I only need to see the I2C data as it goes past and don't need to write to the bus. What would people use to connect to it? Diode & pull-up resistor, op-amp buffers, opto-couple, transistor?
