Author Topic: Is it ok to leave atmega328p reset pin floating?  (Read 16660 times)
Offline abdullahsebaTopic starter
« on: April 10, 2017, 09:28:06 pm »
Hi
Is it ok to leave the atmega328p reset pin floating on the ICSP header?
Or should I add a pull-up resistor?
Thanks in advance.
This is my right hand this is my wrong hand
Online sleemanj
  • Professional tightwad.
Re: Is it ok to leave atmega328p reset pin floating?
« Reply #1 on: April 10, 2017, 09:37:43 pm »
Pull up recommended.
The following users thanked this post: abdullahseba
Offline Psi
« Reply #2 on: April 10, 2017, 09:46:53 pm »
They do have a pullup on reset internally, so it's not really possible to have reset "floating".
If you don't connect the pin to anything then reset simply has a week pullup.
I've left them totally unconnected without problems.
however it's recommended to have a stronger external pull up just in case there is excessive EMI around.
A small cap to ground is also recommended to prevents glitches.
« Last Edit: April 10, 2017, 09:48:48 pm by Psi »
Offline ohdsp
« Reply #3 on: April 10, 2017, 09:50:56 pm »
As PSI/sleemanj said use an external pull. Even if an IC has internal pull-ups these can often be very high impedance (~100kohm).
When adding an external pull up resistor (say 1 to 10kohm) a small capacitor (1nF or 10nF ceramic) between reset and ground can help improve EMI/EMC performance; meaning less "unexplained" resets. If the IC needs a delay on the reset after power up it can also serve this purpose as well by using a larger capacitor.
Check out the Open Hardware DSP Platform:
http://www.ohdsp.org
http://github.com/ohdsp
« Reply #4 on: April 10, 2017, 11:22:34 pm »
So the pullup and caps wont interfere with the icsp?
Online sleemanj
« Reply #5 on: April 10, 2017, 11:38:18 pm »
Typically use a 10k for R1.  It won't affect the ICSP, which connects direct to the reset pin.
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #6 on: April 11, 2017, 07:11:31 am »
Caps on the RESET pin *may* interfere with ICSP.
[2c]
Wrong code should not compile!
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
« Reply #7 on: April 11, 2017, 03:52:02 pm »
Keep the capacitor small enough and it won't interfere. I usually place a 100nF between reset and GND with a pullup of 1k.
Offline Nusa
« Reply #8 on: April 11, 2017, 04:22:13 pm »
If you don't need the reset pin function, you could program the fuses so that it's not a reset pin anymore. Then you won't need an external pullup and you'll also have another gpio pin that you can use. You can still reset via a power cycle.
This trick is more commonly used on smaller packages like the ATTinys where an extra gpio pin is far more valuable, since you have far fewer gpio pins to start with.
Online sleemanj
« Reply #9 on: April 11, 2017, 10:31:06 pm »
Trouble is you can not program it anymore without a high voltqge programmer if you disable reset.
Offline Nusa
« Reply #10 on: April 11, 2017, 11:10:18 pm »
Sure you can, it just takes a timely power cycle instead of a button/host control of reset line. It still gets you into bootloader mode where it looks for an incoming upload for a couple seconds, and the timing isn't that difficult to master. You're right that it's a pretty big inconvenience just to save a resistor. I wouldn't do it unless you really need the io pin.
Now if you screw up programming the fuses, that's another matter entirely! The HV programmer may be the only way out.
Online sleemanj
« Reply #11 on: April 11, 2017, 11:15:39 pm »
It's a good bet that you don't have a bootloader installed on a tiny.  But yes, if you do, then you could do a power cycle reset.
« Reply #12 on: April 11, 2017, 11:17:21 pm »
I think I will install the arduino bootloader on it.
