Author Topic: is there a way I can get a "sharper" cut-off/slope from a passive Low Pass fil.  (Read 2803 times)
Offline ELS122Topic starter
I want to have a sharper cutoff/slope/rolloff from a low pass filter, but I want it to be passive. is there any trickery or anything that can achieve this or do I need to go active if I want a sharp ... cutoff or whatever it's called?
Offline TimFox
There is a large literature concerning passive filters employing R, L, and C in higher-order filter configurations.  “Elliptic” filters have sharp cut-off slopes, but suffer from some responses in the “stop band” above the cut-off (low-pass filter).  They are often used after the DAC in DDS synthesizers.
The following users thanked this post: ELS122
Offline emece67
« Last Edit: August 19, 2022, 04:10:15 pm by emece67 »
Offline Wimberleytech
There are no tricks.  Building a passive filter with a sharp cutoff would be a challenge.  You are better off going active.
Offline TimFox
Note that “Cauer” and “elliptic” filters are synonymous.  These complex passive filters are normally used at high frequencies, due to the required inductors.
thanks, I'll look into the eliptic filter, it seems it would be what I want.
I have considered just increasing the order of a normal RC low pass, but that would decrease gain, and I don't want to decrease gain.
but the eliptic filter looks good!
Online Kleinstein
A first step is to use LC (with R) filters instead of just RC filtering. You can't get the steeper filters like Butterworth or Tschebyscheff with only passive RC - though it is possible to get a simple (but not a good one) passive elliptic filter with only RC.
For higher frequencies ( e.g. > 1 MHz)  LC filters are very viable, while active filters get increasingly difficult (need faster OP).  For low frequencies LC gets tricky and active filters get more viable.
The 100 kHz to 1 MHz range can use both, but neither solution is easy.
Offline Terry Bites
See if you can get hold of "Newhertz Technologies Filter Solutions". Simple fast filter design software.
Fun, helpful and educational!
Offline TimFox
Active filters are great for the audio range, and RLC filters for RF range.  With low-pass filters, the attenuation in the step band can be compromised by low high-frequency open-loop gain for op-amp active filters, and parasitic capacitance (etc.) in the inductors for passive filters.  These are all quantitative questions.  If you know the op amp response and all parasitic, Spice simulation can be used to check the design calculations, since the problem is linear and .AC analysis is accurate.
Offline T3sl4co1l
    • Seven Transistor Labs
- An RC filter is very soft, a single (real) pole.  The roll-off is gradual, and the asymptote is -20dB/dec.
- You can chain RCs, but the roll-off gets even softer.  An RCRC filter (equal values) has two poles, but the effect of each RC on the other causes the poles to spread apart, by a factor of 3 or so IIRC.  Effectively it's a cutoff at Fc then another cutoff at 3Fc.  So the roll-off is very gradual indeed.  You eventually get a -40dB/dec asymptote.
- You can mitigate the interaction effect, by scaling the values geometrically.  You might do an R1-C1-R2-C2 filter with R2 = 10*R1 and C2 = 0.1*C1.  This puts the poles within about 10% of each other, almost as sharp as a single RC but twice as effective.
- This doesn't take you very far of course, as three stages you need 100x the values, etc.
- Aside: you can actually get voltage gain from a passive (RC) filter.  The trick is to use phase shift to your advantage (it is a non-minimum phase filter).  The maximum gain per stage is very small, a few percent.  Just a neat curiosity.
- Active filters use gain elements to raise the Q factor of RC networks, or transform them into other impedances (negative resistance, inductance, etc.).  This is also an aside, as you've specified passive.
- And finally, that leaves inductors.  An LC filter can have voltage or current gain (just not power gain), can have complex poles (giving sharper cutoffs, peaked or ringing response, etc.), but requires impedance matching for consistent response -- the network is part of a power transfer system, and that transfer is completely dependent on the source and load impedances.
You can also mix them, so you have RLC filters with responses somewhere inbetween; some power is lost in the filter, and the cutoff may be softer, but maybe it's more tolerant of impedance mismatch.  Resistance of course is unavoidable in any filter*, but we generally design LC filters with low enough component losses (high Q inductors, capacitors) that the insertion loss is usefully low.
*Yes even superconducting filters!  There are still loss mechanisms even in otherwise-ideal conductors.  The trick is, superconductors are fine at DC, but at AC, all bets are off.  In the extreme, consider a puck of YBCO: it's black, and doesn't change color with temperature.  It's not superconducting at optical frequencies at least.  It actually follows that, somewhere between DC and light, there is a cutoff where resistance takes over, and indeed there's an obvious quantum-mechanical reason for that.  They can be quite excellent though: Q factors of 10^7 or so, better than most quartz crystals.  Optical resonators too (built from dielectric supermirrors).
Seven Transistor Labs, LLC
The following users thanked this post: daqq
Online Benta
For higher order passive filters (= sharper cut off), you need both inductors and capacitors.
There's no way around it, and the maths concerning this subject have been around for centuries.
Online srb1954
  • Retired Electronics Design Engineer
This is incorrect. It is usually easier to design a sharp cut-off passive filter than an active filter.
Passive filters can be easily synthesised using classic design techniques or from filter design tables and the resulting filter designs are less sensitive to component tolerances than in active filters.
Active filters are more difficult to design, particularly for high performance filters with sharp cut-offs, as there are fewer standard design techniques for these. The resulting designs can be quite sensitive to component tolerances and active component performance. In the case of very high performance active filters trimming of components is often required to meet performance targets.
Online ejeffrey
You can make high order passive RC filters with no inductors.  The component values get pretty annoying, but it certainly works.  High order != sharp cutoff.  High order refers to the number of poles and the ultimate slope of the rolloff.  For a sharp transition region you need complex pole pairs which requires either inductors or active filters.
You can also make buffered passive filters where you use a passive RC for each stage with a buffer amplifier between them.  It's not what I would generally call an active filter, but it lets you make a multi-stage filter without the component values getting silly.
Offline RandallMcRee
A sensible answer requires as input the frequency Fc (-3dB point) and the required steepness.
Get out yee old filter calculator and do some checking! Lots of tradeoffs.
E.g. Marchand electronics sells passive filters for audio purposes you can get 24dB slopes at 80 Hz.
https://www.marchandelec.com/xm46.html They are expensive.
« Last Edit: January 19, 2021, 04:57:44 am by RandallMcRee »
Online srb1954
The first step is to list the performance requirements and consult a standard filter design textbook to determine the required filter configuration (Butterworth/Chebyshev/Elliptic ...) and the number of poles (basically the number of reactive components in the circuit) required to meet the performance specifications.
The next step is to determine whether to go passive or active. High performance passive filters require inductors but are easily designed using standard synthesis techniques or from tables in a filter design text. Passive filters are usually more appropriate for higher frequencies where the inductor and capacitor sizes are more manageable.
Where you don't want to use inductors or for lower frequency filters where inductors become prohibitively large active filters are another option. The overall filter response has to be split up into multiple stages for synthesis into standard active filter building blocks, which usually only handle 2 poles per active stage. Standard design techniques such as Sallen & Key and Multiple Feedback exist for these active filter building blocks but these are generally only usable for lower performance filters with Butterworth or Chebyshev response. More elaborate active filter blocks and design techniques are required for producing active elliptic filters.
Offline Terry Bites
What is your cut off frequency (-3dB) point?
what slope do you need db/decade or db/octave?
What is the maximum attenuation you need?
Is your signal pulsed or continuous?
Is this an AF or RF filter?
Online Benta
Please show us how, with the associated topologies and transfer functions.
Offline T3sl4co1l
Order is simply the number of poles.  Not how sharp they are.
RC filters are all real poles (or zeroes).  Soft cutoff, same asymptote.
Online Benta
The problem is, that a higher number of real poles does not result in a higher order filter. They can be lumped for a final cutoff slope, which will still be -20 dB/decade = 1st order filter.
Like a ski slope that undulates a bit, but the final slop is still the same.
@ejeffrey: please show us your n-order RC-only passive filter.
Offline T3sl4co1l
I'm not sure how long it's been since you solved a transfer function?  It's not hard to show, good homework, do recommend. :-+
Example sim attached.
Offline TimFox
The "trick" for the example above is that the resistors increase by a large factor from input end to output end, with capacitors scaling in the opposite direction for equal time constants.
Offline T3sl4co1l
As I described above -- the geometric series is only used to keep the poles close; the asymptote is identical in any case.
Offline TimFox
Yes.  The poster was asking for "trickery" to obtain the "sharper slope".
Online Benta
Conceeded. :)
You've demonstrated a triple first-order filter. Bravo! I don't want to bicker about naming conventions here.
Your professorial tone about homework is not nice, though. I'm 60+ and have solved plenty of transfer functions, but mostly in audio/video, where somewhat more advanced filters than your three resistors and caps are needed.
Cheers.
The following users thanked this post: Wimberleytech
Just for the sake of argument, and I know you are a smart guy (I read your posts), would you truly characterize a three-pole real-axis filter as one having "sharp" cutoff?
