I have no idea what you are talking about. I was commenting on someone else's remark about output capacitors blowing up LEDs. I was not talking about voltage regulation at all but fast response in the current limiting circuit.
My power supply design uses no inductor in the current limiting circuitry and as you can see from the video, get's the job of not blowing up LED's done just fine.
As to a schematic, this would not be the place for it, would it? This would be the place to discuss what the OP needs for his lighting experiments, and I stand by my suggestion that a decent bench power supply would be ideal.
I get the feeling you're trying to pick a fight. Let's not do that.
The OP is talking about a lab PSU. I was merely stating that lab PSUs are primarily designed for constant output voltage, rather than current. It might work, but one has to be careful about how they use it. The suggestion of setting the voltage to zero first, is a good idea and will help to avoid damaging the LED.
Why not post the circuit here? It's very much on-topic.
I have no intention of picking a fight. What gives you that idea?
It might surprise you to know I am quite familiar with power supply design.
The output capacitor should not be placed after the current sensing. A decently designed and built power supply would specify a current error amplifier with a decent bandwidth so that the current can be limited within a us or so.
How can that produce decent voltage regulation?
And you need an inductor, not a capacitor for good current regulation, at high frequencies.
I have one right here I designed myself. I set the voltage to 12V and the current to 15mA and I can connect LEDs till the cows come home without killing a singe one.
If you have a power supply that will kill an LED under those conditions, throw it out now!
Please post a schematic.
You don't really need an inductor for that. When I was making battery tester for a living (CC), we had a difference amplifier across a shunt, providing feedback to the error amplifier. This for CC control. CV was software. If you want hardware control, for CV, you have an amplifier measuring the output voltage. Make the error signals a current drain, then whichever is smaller will control the output, and in a one quadrant supply one of them will always be positive. Because it's either CC or CV, so one error will be zero, the other positive. There is one extra step, preventing the error amplifier from going into saturation, eg. diode in the feedback, and you have a quick CC CV controlled supply.
A battery charger isn't a generic lab power supply.
You don't need an inductor for using a constant current source to drive LEDs and the like, but it's needed at higher frequencies, just as a voltage source doesn't need an output capacitor for many applications, but it becomes important at high frequencies. Anyway, I suppose that was off-topic, since this thread is about LEDs.
The problem is when CC is being switched to CV and vice versa, it results in current/voltage spikes. An output capacitor will help to minimise the voltage spikes, at the expense of increasing the current spikes. An inductor will reduce the current spikes, at the expense of increasing the voltage spikes.
