I built an opamp circuit on a 3M breadboard. There is a 560pF cap in place to keep the opamp from oscillating, no problem at all. However, sometime when I remove this cap, the opamp will remain stable. Another time I remove it, the circuit will oscillate. Something if I tile the jumper wire at an angle, the circuit will oscillate. So, is this problem caused by the breadboard or the circuit itself is at the edge of stability?
