I'm sure I'd come across a youtube review that had favourably compared the Siglent against Hantek and Rigol (possibly even a low end Tektronix model) about a year back but, try as I might, I can't track it down. I ran an 'Impulse Test' on my own Siglent SDS1202X-E at the time, which needed very high levels of mechanical abuse to get anywhere near the voltage levels demonstrated by the other brands used in video reviews that had included such 'Impulse' testing.
I have to admit that I was feeling a little smug after this test. For all I know, Siglent may even have specifically chosen low piezoelectric effect types for the more critical signal path areas to minimise susceptibility to this piñata effect.
Of course, it could just simply be down to 'dumb luck' that the component placement/circuit layout happened to be less susceptible to this microphonic effect than that of their competitors' products. Either way, I'm a "happy bunny".
JBG
All Siglent models use BNC's of a bulkhead style so when fastened to the chassis any PCB any microphonic susceptibility is greatly reduced. This also eliminates the chance of BNC's breaking free from the PCB like was common in Tek TDS210/220's.
Thank you for that insight. It rather suggests that Siglent have a tighter control over their bean counters than their competitors, limiting the damage they can inflict on a company's reputation just for the sake of a fraction of a percent boost in profit margins. It seems I have every justification to declare my smugness at making such a wise choice.
I've also just recently discovered yet another reason for being so smug. In the "eevblog.com/forum/buysellwanted/re-feelelec-new-arrival-fy-6900-signal-generator" thread, the issue of trying to interpret the noise and ripple from waveform traces alone when testing the original smpsu against home brewed analogue PSU concoctions intended to "improve" this dirt cheap function/signal generator (as with its predecessors, the FY6600 and FY6800 models) had come up.
The point had been made that, whilst waveform traces can reveal clues as to the nature and size of the problem, the only sane option is to use a half decent (or better if your pocket is deep enough) Spectrum Analyser for this task. If you don't have such a device, then 'scope traces are the next best thing, being better than nothing at all.
This got me to wondering whether the built in FFT function in the Siglent models could stand in as a "Poor Mans' half decent Spectrum Analyser". I had already seen very favourable reviews of the FFT feature in the recent Siglent SDS1000 series of DSOs were the FFT performance rating had been placed well above that of its competitors so I was curious to know whether I could get any useful noise spectra with this built in FFT function.
My initial tests had concentrated on the PSU noise and ripple aspect so I'd set my FY6600 sig genny to output a 0.3V "DC Waveform" to restrict my observations to only the noise and ripple effects, sans any possibly confusing test waveform (the 0.3 DC voltage is readily ignored (the 'scope, indeed all 'scopes, have a switch dedicated to the blocking of such DC voltage interference already built in
The 0.3V output setting wasn't a random choice. The FY6xxx series (so far) switches a 20dB ish attenuator into the output for dc voltage output settings below the 250mV mark (corresponding to the 500mV p-p threshold applied to all other waveforms) which would attenuate the very noise I was looking for. I posted a couple of these FFT graphs to the FY6900 topic thread for other cash strapped hobbyists to peruse and compare to the noise and ripple components of their own PSU upgrades.
Since the efficacy of budget entry level DSO's FFT features had been questioned, it occured to me to post a more familiar looking spectrum of a carrier wave tone (10MHz 1Vrms - 0dBV in my case) for those members with an interest in applying such modifications to their bargain basement function generators. The results looked quite impressive compared to my earlier attempts at using this feature.
Quite frankly, my earlier failures to get a usable plot had simply been down to my unfamiliarity with what can be a complex setting up process compared to the basic function of getting squiggly lines to appear on the screen. Having finally worked out how to optimise the FFT settings, I thought I'd post my own plots to not only demonstrate the FFT feature but also offer clues to the required settings for the benefit of any who may have (like I had) dismissed the FFT feature as a useful tool in assessing PSU noise and ripple (and signal quality in general) simply due to being unimpressed by their initial experience with this feature on a freshly acquired "Entry Level DSO".
I've attached these FFT plots so you can see what I'm blathering about ("A picture is worth..." and so on - you get the picture, assuming I manage to successfully attach them, that is!). Oh, and one more point (I'd almost forgotten to mention - actually did, this is an edit), Please note that the 10MHz peak is 20dB off the top of the plot since I had to set the reference level to -20dBV in order to display the noise floor.
JBG
