To what end -- is this at high frequency, mains, DC? How is it wired, that there is room for a jumper?
Does the datasheet say the dies are matched, so they are okay to wire in parallel? (Dual diodes are often separate dies, so their temperatures won't track as well as could be. As a result, the maximum current rating for two in parallel, will be somewhat less than double the rating of each diode. How much depends on how well matched they are.)
