If you will be working with voltages over 50V, much of your investment will need to be in enough differential voltage probes and isolated current probes, with sufficient bandwidth to monitor key parameters of all the phases of your drive's output stage. If its a direct from mains drive, the probes had better be at least Cat II rated, with an adequate working voltage margin above your worst-case DC bus voltage.
Otherwise, *when* (not if!) your new drive design decides to convert itself to silicon shrapnel, its got a high probability of taking out your scope, and possibly its operator as well, leaving no signal data for a failure analysis, (and if you were dumb and won a Darwin award by floating your scope, no-one to do the failure analysis)!
