H all,i have a dell inspiron 1720,trouble is te wires break in the charger cable,where they enter the barrell conector,this leads to charger not beeing recognised,means it will power the laptop but wont charge the battery,is there a name for te connector so i can fit a replacement,or a way of bypassing the data center pin,ie does the lappy pull it low etc?,TIA
