Hello,
I have a smart electricity meter that has a data output at 9600bps, on-off keyed on a 50 kHz carrier frequency. The carrier is a distorted sine, around 5 Vpp, available on a terminal block where the user is expected to connect twisted pair. This output is isolated from everything else by a signal transformer. There is a mains-rated cap in series with one of the legs at the secondary of the transformer, to limit the current to a non-destructive value in case someone accidentally connects mains to the terminal block. This cap is the only thing present at the secondary, besides the terminal block.
I was playing around with interface circuits in order to read the data stream with an Arduino or Raspberry etc., and I noticed something odd :
I placed an LED in series with a resistor across the two output terminals, and was expecting the LED to light up with varying brightness as bits are transmitted. (the meter is transmitting continuously). I thought that in this half-wave rectification scenario, the LED would let current flow during one half of each cycle and light up accordingly. But no... the LED doesn't light up. Instead, here's what I found:
- I'm not able to measure any current in the LED by probing the series resistor with my Analog Discovery (which has diff inputs)
- the LED emits a very brief and dim little flash of light when I connect it (with its resistor) in one way; then nothing, then again a brief flash if I manually swap the wires.
- when touching one of the legs of the LED with my fingers, there seems to be some sort of leakage and the LED lights up very dimly
- if I add another LED in antiparallel with the first one, then the two LEDs light up brightly as bits are transmitted. Same thing with a 1N4148
How is that possible? I'm puzzled. I know it's a good idea to put another diode in reverse across the LED to clamp the reverse voltage and avoid damaging the LED, but I can't see how this second diode could be needed for the first LED to light up in the 1st place... Is this "blocked-in-OFF-state" thing a standard feature for LEDs that I just didn't know?
Also,
- I used my Analog Discovery to output a 50 kHz sine into the same LED + resistor arrangement, this time the LED lights up as expected
- I also tried to record the actual waveform with my AD and then play it back : same thing, the LED lights up
- in the electricity meter, the secondary of this data output transformer is fully floating. So I repeated the two tests by adding another transformer (salvaged from another utility meter, so I know its suitable for 50 kHz) after the AD2 : same thing, the LED lights up again
That's not really a problem (I have a working demodulator, some of you may remember old posts of mine about that) but I'm just really curious. Thank you for any hints about what could be happening that prevents current from flowing into the LED!
