I said "remove the link to Vcc". That's the wire going straight up from the top end of R4, above the T junction. Once you've removed that, it should be O.K.
Looks reasonable. I haven't checked the pin numbers against the datasheet so double-check them. Otherwise its time to breadboard it and see if it works.
