I really appreciate the schematic, I was having a hard time seeing the DPDT, and now it is much clearer.
Is defeating the pressure switches on the other 9 control boxes wise? What are the safety and process ramifications of that? It's not something I'd do without FULLY understanding ALL the risks it brings.
I am 100% that this is OK to do, I do it all the time for other tests. Thank you for verifying.
In fact, I use another set-up that uses only 1 control box to verify 10 switches for a different application, let's call that set-up B. I think I will test my solution on set-up B first.
For the 10 control box set-up, let's call that set-up A, I would have a single tower light like discussed but ideally there would also be smaller indicator LEDs for each control box, making troubleshooting a failure easier. I believe your schematic allows for this addition. This was issue #2 in my original post, but that really made things confusing, so I eliminated that idea for the time being. I have come a long way since then; this forum is a great resource. I am glad I decided to reach out, and look forward to following the discussion board.
I will post updates as my project progresses.
