Hi there!
I recently acquired an old Precise 111 Tube Tester, but it seems to be a problem somewhere as I get the "Fuse" light on when I adjust the line voltage level (no tubes in any socket). As I approach the "?" indicator in the panel, that is, the correct line voltage, the fuse light goes on and stays bright. If I reduce the line voltage pot, the light goes off.
This light bulb must be a GE-81 (6.5V 1.02A) but what's in there is as GE-67 (13.5V, 0.59A) instead. I have been told that using the wrong bulb may well be the problem and so I've ordered a couple of correct #81 bulbs. Unfortunately the mail service is greatly delayed due to COVID and a very strong snow storm we've suffered recently and I haven't received them yet. I have checked the tube tester wiring (a real nightmare!), recapped and corrected some resistors that have drifted in value and everything seems OK except for this bulb.
This is what the Precise 111 manual says about that light:
FUSE LAMP
This automobile type bulb is in series with the 110 volt line and serves as a fuse for over-loads. On certain tubes it may glow dimly, but under no circumstances should it glow brightly. If it does, turn instrument off at once and recheck all switch settings.
The construction manual for the Precise 111 indicates that this bulb is a "B81" lamp which I understand to be the same as a "#81" or "GE-81" automotive bulb.
I do not fully understand the rationale for using such a low voltage bulb (6.5V) in series with a 110V power line. Wouldn't it vaporize instantly?
Evidently not because this has been used for decades in many circuits, notably in tube testers like this. Please anyone can shed some light (pun) on this?
Thanks a lot in advance.
