Author Topic: Lithium battery BMS behaviour  (Read 1402 times)
Offline anso-engineerTopic starter
  • Country: ua
« on: October 19, 2026, 09:05:48 am »
Hello, yesterday I have challenged some BMS issues, but afterwards I have found this is probably OK...
I have connected 18650 3.2 battery and  later 26650 3.2 battery to the smal BMS PCB, in the package was only pcbs, so I solder nickeled strips to board and welded strips to the battery respectively. In the end I got I bundle 18650 and one bundle 26650.
Afterwards, I have checked voltage on P+ and P- contacts. Zero volts!
  • B+ and B- clamps 3.2V - OK
  • P+ and B- 3.2V - OK
  • B+ and P- - 0V
Frislty I assembled 18650 there was clear voltage between P+ and P- ,but not for the case with 26650.
I connected smal diode between 26650, P contacts, it didn't lighted. Afterwards I connected 0.2A load between P+ and P- and load was detected.
I can't have other explation as 26650 has some internal limitation or something as this.
Offline sleemanj
  • Professional tightwad.
Re: Lithium battery BMS behaviour
« Reply #1 on: October 19, 2026, 09:18:15 am »
It's not too easy to follow your post, but  most likely you are seeing the result of battery protection.  When first connected, or after a low voltage cut off, such protections usually require a charge voltage to be connected to wake them up.
The following users thanked this post: Kilrah
  • Country: ua
« Reply #2 on: October 19, 2026, 09:30:03 am »
Maybe I should somehow read this tiny values of components and it helps understand something.
And yes, I will check it after first try of charge.
Offline ME
« Reply #3 on: October 28, 2026, 02:39:12 pm »
is it for an fpv drone battery?.
