Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
LM2577 High Current with mosfet
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LM2577 High Current with mosfet (Read 2794 times)
tomshirvo
Regular Contributor
on:
July 22, 2015, 03:47:23 am »
So I am just wondering if with this LM2577 if I can use the "Switch" pin to connect to a mosfet or transistor to allow more than 3A of output current capacity. I know I would also require the other passive components to be rated for the current but I am looking at a 10A output. I want to be able to get 6V to 12V with 10A output!
Is this possible?
http://www.ti.com/lit/ds/symlink/lm2577.pdf
Thanks
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: LM2577 High Current with mosfet
Reply #1 on:
July 22, 2015, 08:42:15 am »
Not without a much larger pile of logic. Those things are ancient, slow and inefficient, anyways -- there are better around!
Go with a modern controller, e.g.
http://www.digikey.com/product-detail/en/TPS53014DGSR/296-30492-1-ND/3431366
for buck, which is also synchronous (better efficiency at low output voltages, if you need it), or
http://www.ti.com/product/lm3478
for boost (which is peak current mode, so also mind your inductor selection).
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
