Author Topic: LM324 Power Supply with variable voltage and current  (Read 173454 times)
Offline mike_mikeTopic starter
Re: LM324 Power Supply with variable voltage and current
« Reply #750 on: June 06, 2021, 06:34:48 am »
Not yet. I will try to do some tests.
« Reply #751 on: June 06, 2021, 07:06:55 am »
I tried some tests with PSU Shorter. The load resistor was 0R, so I tested the PSU to short circuit response until now. Blue trace = pin 3 of LM555, yellow trace = output of PSU.
1. Vout=1.75V
a. Iout=2.6A 97_001, 97_002
b. Iout=1.3A 97_006, 97_007
c. Iout= almost minimum 97_008, 97_009, 97_010
2. Vout=15.14V
a. Iout=2.6A 97_013
b. Iout=1.3A 97_014
c. Iout= almost minimum 97_015
3. Vout=30V
a. Iout=2.6A 97_022, 97_023, 97_024
b. Iout=1.3A 97_019, 97_020, 97_21
c. Iout= almost minimum 97_016, 97_017, 97_018
Please have a look and tell me if the results are good ?
The next step should be testing with different loads, what resistor values should I use ?
« Last Edit: June 06, 2021, 07:09:26 am by mike_mike »
Online xavier60
« Reply #752 on: June 06, 2021, 07:30:33 am »
Test at 1 amp without going into CC mode.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
« Reply #753 on: June 06, 2021, 09:36:21 am »
It's oscillating at 1A load, current pot set to max output current, without going into CC mode.
1. 10V output, 10R load: 98_000, 98_001
2. 20V output 20R load: 98_002, 98_003
This mean that I should modify the value of C3 and C4 ?
« Last Edit: June 06, 2021, 09:39:00 am by mike_mike »
Online xavier60
« Reply #754 on: June 06, 2021, 09:43:14 am »
I need to see how it's laid out. Try decreasing R5 and increasing C3.
« Reply #755 on: June 06, 2021, 09:48:36 am »
This is the layout that I made for this psu. I wanted to connect the 2 pots on the PCB by using 2 terminal blocks.
The PNP power transistor (Q2), 2x TIP35C, 1n5404, emitter resistors (R14,R15), the 100R resistor (R13) and R11 are on the heatsink.
« Last Edit: June 06, 2021, 10:05:20 am by mike_mike »
« Reply #756 on: June 06, 2021, 10:03:28 am »
I increased C3 to 220pF and I decreased R5 to 8k2.
1. Vout = 20V, Rload=20R: 99_000, 99_001
2. Vout=20V, Rload=10R: 99_002, 99_003
3. Vout=10V, Rload=10R: 99_004
Online xavier60
« Reply #757 on: June 06, 2021, 10:35:51 am »
I would not have expected that small a change of R5 to make such an improvement. Are you certain that C3 was really a 150pF?
The ringing in bmp_99_001 could possibly be happening externally to the PSU. The probe should be connected at the PCB.
If the ringing is external, the amplitude will be greater as the probe is moved closer to the shorter.
Online xavier60
« Reply #758 on: June 06, 2021, 10:40:42 am »
Anyway, I see that the response is 5uS, unnecessarily fast.
Make R5 4.7K and C3 470pF.
« Reply #759 on: June 06, 2021, 10:44:59 am »
Yes, C3 was really 150pF.
Right on the output of the PSU: 100_000, 100_001
On the PSU Shorter: 100_002
Online xavier60
« Reply #760 on: June 06, 2021, 10:51:04 am »
That proves that the ringing is external. Try those other values.
For example, my Agilent PSU has a 30uS response.
« Reply #761 on: June 06, 2021, 10:55:07 am »
I tried with R5=4.7k and C3=470pF
Vout=20V, Rload = 20R
« Last Edit: June 06, 2021, 10:57:49 am by mike_mike »
Online xavier60
« Reply #762 on: June 06, 2021, 11:08:49 am »
Odd that it didnt change much and the ringing is large again?
Online xavier60
« Reply #763 on: June 06, 2021, 11:11:03 am »
Show us mainly the voltage dip when load is turned on.
« Reply #764 on: June 06, 2021, 11:13:14 am »
I tested again, it was my mistake, because I connected the ground clip to the wrong point.
« Reply #765 on: June 06, 2021, 11:18:30 am »
Online xavier60
« Reply #766 on: June 06, 2021, 11:26:31 am »
The 5uS/Div shot shows all that's important. It all looks fine, could be a bit slower.
Lastly, I would like to see how much the voltage steps at the Base of Q1 during the 1 amp step load.
It will tell me how much gain your output stage has.
« Last Edit: June 06, 2021, 11:28:51 am by xavier60 »
« Reply #767 on: June 06, 2021, 11:32:44 am »
Please find attached...
Online xavier60
« Reply #768 on: June 06, 2021, 11:43:03 am »
The gm is 8, close to typical and doesn't explain why this build needed different compensation.
Need to see a few more built.
« Reply #769 on: June 06, 2021, 11:50:16 am »
Does the circuit need more testing ?
I would like to know this because I want to build a case for the PSU...
Online xavier60
« Reply #770 on: June 06, 2021, 11:54:17 am »
You could do some more test at different load currents to be sure.
« Reply #771 on: June 06, 2021, 12:15:46 pm »
Can you please recommend some load resistors for the PSU shorter and the values for the output current and voltage in order to test the PSU at key points ?
Online xavier60
« Reply #772 on: June 06, 2021, 12:20:23 pm »
5 and 10 ohms. You can adjust the voltage to get various currents.
Start at 100mA with your 20 ohm.
« Reply #773 on: June 06, 2021, 12:49:49 pm »
I tested with 5R, 10R and 20R as load, the current pot was set to maximum.
A few of the results:
Vout = 30V
Rload = 10R: 102_025 to 102_028
Vout = 12V
Rload = 20R: 102_12 to 102_014
Vout = 2V
Rload=5R: 102_007 to 102_011
Please have a look and tell me what you think.
Edit: I also measured the minimum output current, which is a few milliamps. When I rotate the current pot to minimum, the red led does not light up, until I connect a overload to the output of the PSU, for example a red led.
« Last Edit: June 06, 2021, 04:04:12 pm by mike_mike »
Online xavier60
« Reply #774 on: June 06, 2021, 07:26:35 pm »
The overshoot looks normal. Ill compare it to mine later.
The minimum current not going to zero could be due to opamp offset. If the opamp is socketed, try a few others.
If I had of anticipated this, the problem could have been covered up by a high value resistor from 5V to the inverting input to give it a definite negative offset.
