Given the almost 50Hz repetition rate of those pulses it's probably something mains-related, although I'm not sure why the pulses from the diffamp output are so sharp.
Perhaps the diffamp output is a result of heater power turning on and coupling a pulse of noise into the sensor wires. As for the turning on of the heater, it would be due to peaks of mains noise received by the sensor wires.
Zoom in and see whether the blue pulse comes before or after the first yellow pulse.
