I am a beginner in circuit design and had a question about back-feed protection for an LM7805 voltage regulator.
The circuit I am designing contains multiple IC's and an Arduino that are all powered from a 5-volt rail that comes from an LM7805.
I would also like to add a USB connection so that I can program the Arduino. The 7805 will not be supplying power while the USB cable is attached, the 5-volt rail will be powered through the USB cable.
My question is, what is the best method for protecting the LM7805 from back feed voltage when the 5v rail is being powered over the USB cable.
My first thought was to simply put a diode on the 7805's output, but that would drop the regulated voltage so it's not optimal.
Thanks.
