Author Topic: LM7805 climbs above 5 volts why  (Read 3623 times)
Offline ascotTopic starter
« on: July 21, 2020, 03:58:36 pm »
just tried the 7805 for first time knowing it's a 5 volt regulator up to 20 volts it stays stable about 5.08 volts but any higher the voltage climbs data sheet says 25 volts max any ideas on why its climbs above 5 volts with input over 20 volts
Offline KMoffett
Re: LM7805 climbs above 5 volts why
« Reply #1 on: July 21, 2020, 04:04:55 pm »
Where did you buy it? May be an out of spec regulator that was dumped by the manufacturer and picked up by someone that acquires junk and sells it as new.
The following users thanked this post: ascot
Offline tooki
« Reply #2 on: July 21, 2020, 04:06:32 pm »
How much higher are we talking? I looked at a few datasheets and they specify an output voltage of 4.75-5.25V.
« Reply #3 on: July 21, 2020, 04:09:38 pm »
25 volts takes it to about 7 volts
Offline TimFox
« Reply #4 on: July 21, 2020, 04:11:06 pm »
Exactly which model of "7805" are you using, including prefixes, suffixes, manufacturer, and case size?
The following users thanked this post: Yansi, ascot
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #5 on: July 21, 2020, 04:15:24 pm »
Yes, running a LM7805 with more than 20 V input voltage is bad design.
Also you may need 10 uF capacitors close (< 5 cm) to the regulator in order to avoid oscillation. Put one on input and one on output.
Regards, Dieter
Offline wraper
  • Country: lv
« Reply #6 on: July 21, 2020, 04:32:51 pm »
Likely it's simply a counterfeit. Unless datasheet of particular manufacturer shows lower maximum voltage.
The following users thanked this post: WattsThat, ascot
« Reply #7 on: July 21, 2020, 04:33:42 pm »
love to tell you all the package type but microscope went on the blink as a side note tried 1 from 2 different suppliers both read 6.68 volts at 25 volts input
Offline wraper
  • Country: lv
« Reply #8 on: July 21, 2020, 04:35:36 pm »
7805 is not an LDO and is fine with 0.1uf cap. Datasheet of 7805 from Ti even says it's stable without output cap.
Offline TimFox
« Reply #9 on: July 21, 2020, 04:44:14 pm »
The original data sheets for the 7805 required a minimum input capacitor of 330 nF (unless the device was extremely close to the filter capacitor), and I sometimes saw high-frequency oscillation (> 100 kHz) when that requirement was ignored.  Perhaps this circuit is oscillating and was only measured with a voltmeter?
« Reply #10 on: July 21, 2020, 04:47:54 pm »
there is 2 10uf capacitors on input , output could be its only rated 20 volts was from amazon after all
Offline MarkF
« Reply #11 on: July 21, 2020, 04:49:56 pm »
You also need to provide a 5mA minimum load current.
The following users thanked this post: Bassman59, ascot
Offline TimFox
« Reply #12 on: July 21, 2020, 04:53:56 pm »
Yes, the output voltage is only specified for Iout > 5 mA.
« Reply #13 on: July 21, 2020, 05:01:15 pm »
thanks to all who replied especially the load reply was doing it without a load put an led in now registers 5.08 volts at 25 volts side, note go above rated amps and it
smokes :)
nice to know can find answers to questions
The following users thanked this post: shaunakde
Offline NivagSwerdna
« Reply #14 on: July 21, 2020, 05:08:17 pm »
Have you assumed anything about the connectivity tab/heatsink? Might be worth checking... i've certainly got that totally wrong in the past!  :palm:
Offline wraper
  • Country: lv
« Reply #15 on: July 21, 2020, 05:09:19 pm »
That is not true at all. For keeping output voltage you need the load only for adjustable regulators like LM317 and sort of. 7805 bleeds output current internally through quite low resistance internal feedback resistive divider. Datasheet may specify output voltage at certain current range but it does not mean that below this current output voltage will raise to any significant extent.
« Last Edit: July 21, 2020, 05:17:17 pm by wraper »
The following users thanked this post: basinstreetdesign
Offline shaunakde
    • Shaunak's Lab
« Reply #16 on: July 21, 2020, 05:18:18 pm »
I was about to ask about the load. I had something similar happen with a negative 12-volt regulator: LM7912. It behaved pretty badly before I added a small load. You can see this happen on video to SDG Electronics around the 18 min mark.
See: https://youtu.be/ML-lmuHoh-0?t=1107
 Since watching this video, I have just always added LEDs on the output. :)
« Last Edit: July 21, 2020, 05:21:22 pm by shaunakde »
Offline wraper
  • Country: lv
« Reply #17 on: July 21, 2020, 05:27:08 pm »
I just grabbed LM7805 from National semi and it kept 5V output all the way up to 60V input voltage my PSU could supply. No input/output capacitors and load attached.
« Last Edit: July 21, 2020, 05:28:56 pm by wraper »
Offline wraper
  • Country: lv
« Reply #18 on: July 21, 2020, 05:32:05 pm »
Most likely it was a counterfeit trash as well.
Offline bdunham7
« Reply #19 on: July 21, 2020, 08:00:27 pm »
Can you measure the input supply current?  I just tried this with an ST L7805CV part from a scrapped HP power supply (so I'm pretty sure it isn't fake) and it maintained 5.03V +/- 10mV from 6.2 to 25V input, but it had a no-load current draw of about 5-7mA.
Offline Zero999
  • 0999
« Reply #20 on: July 21, 2020, 10:20:30 pm »
You could add a resistor in series with the LM7805.
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #21 on: July 22, 2020, 05:26:44 am »
If someone designs a circuit based on tests like that or on datasheet limits, there will be a bad surprise later on. I can walk on one foot for a while, but the conclusion to buy one shoe only is certainly bad. The reason for not using a LM7805 with more than 20 V input is heat.
Only recently i fixed a Keithley 213 quad DAC (a rebranded IOTECH DAC488) that has four 5 V regulators running from 31 V input, all without heat sinks, at 55 mA each. That can't work. One of the regulators was burnt, although in theory they have built-in over-temperature protection. All capacitors were dry from heat, so the other three regulators were oscillating. What a mess.
Regards, Dieter
Offline james_s
« Reply #22 on: July 22, 2020, 06:19:26 am »
What on earth were they thinking feeding the regulators with 31V?
Offline Zero999
  • 0999
« Reply #23 on: July 22, 2020, 07:32:52 am »
Regards, Dieter
I don't think he's advocating using the LM7805 at 60V, just that based on his test, a high input voltage is unlikely to be the cause of a higher than normal output voltage.
The maxium recommended input voltage for the LM7805 is 25V, so the Keithley is using it out of specification. The power dissipation issue can be fixed with a series resistor.
https://www.sparkfun.com/datasheets/Components/LM7805.pdf
Offline tooki
« Reply #24 on: July 22, 2020, 08:59:40 am »
Regards, Dieter
No, it’s not out of spec. Some datasheets recommend 25V, but many do not, leaving only the maximum input voltage of 35V or 36V, which 31V is comfortably below. What the designers at IOTECH clearly didn’t look at were the graphs explaining how much current one can draw at a given voltage differential...
